DR and animations
Guys can i use DR for Animations cos every time i try, this happens, so do i have to do through BB?
Doing a test through BB .. so i guess i will answer my own question ..
yeah so Dr doesn’t do UHD on animations? odd?
Hi, the uhd file should be transferred like any other asset, if it’s not, then it’s a bug indeed.
Does it work fine if you make sure that the nodes have access to it, for example by placing it on a network drive?
Regardless of any bug which may hide here (and probably has the origin in the double extention “.hdc.uhd” for the cache file):
It makes no sense (only for rare and special cases) to use DR for animation. You already have setup BB, that´s the way to go here.
Good Luck
