We have just installed another machine which can see the manager - and the manager can see it but, when the render is sent to it - it says ‘Render Error - Render Failed’.
We are using SP1 and have had no problems with the other machines until this one.
Does anyone have any suggestions ?
N
I think you have to at least send one job through backburner (can be a standard scanline job) to be able to use DR. Also make sure the Vray-versions and used plugins on workstation and nodes are the same.
The vraylog.txt on the new machine might tell you more about why the error occured.
Greetings,
Ruud
Its all very odd.
I can get all machines working individually but not together !
There is one machine in this group with a full licence but, that shouldn’t matter.
