Hi, im rendering some small scene, all the assets are on the server for all pc (currently only 1 master 1 slave) Same 3dmax versions
Here is the screen , notice the brighter part of the image (with more time it become more and more withish) So what can i do? i have i BIG project in the next week and i really need to use DR
(vegetation done with forest, Corona Sun only light in the scene)
Keymaster need the scene??
I have those kind of stripes all the time when rendering in network, but they do disappear after some more passes. Try to render more than 6 like it is in your case.
So here are my test, in the first you can see the red bench witha strong red tone and a more girly one
In this case there is a renderable spline inside with corona light mat, and a texture with self ilumination.
as you can see the more time pass the effect covers the whole thing.
And the second test has the lights turned off, and you can see some textures are getting brighter as time pases.
So i really think there is a bug here, I CANT use dr on this scenes and i have a BIG one in the next week so im worried about it…
I attach some psd files with the “time lapse” so you can see ..
Hi Rawalanche, im checking the scene and the “status” of all the items on the Asset tracking says “network path” So any more ideas to test? could it be releated to network settings inside my office? (i dont have the control over it, but can ask for test or changes )
i got these problems sometimes too. Here it seems like the problem is caused by one special slave.
My workaround is not to use this Slave for DR when the problem occurs.
Maybe you can find out which slave(s) cause the problem and use the others.
Hi Lucutus, i try with both slaves with no luck, every time i get a washed image or a fragment of it. im going to test at my house and see if some network config is screwing thing up…
But the IT department arround here is half dumb…
Have you tried right clicking your assets in asset tracking and clicking “Resolve Path to UNC Location.” Also try changing the synchronization interval from 60 seconds to something like 5 seconds. These two things worked for me. Hope it helps!
Still nothing, and i dont really know what causes it. just glad that some one else is having it and its not my pc or network config… Hope the devs can sort this . For me its critical bug.
Hope it be fixed for 1.0
If you find it please let me know and i do the same.
Testing, testing, and no improvement.
So I changed the paths to UNC in References / asset tracking, and SO FAR, NO ERRORS. The image is perfectly rendered. Magic! Magic!
Anyway, as I’m not entirely convinced, I will continue to test and comment on how I go.
@z8er that would “kill” your network… Let’s say you have 4-5 nodes and they sync in 5 seconds… so much unnecessary traffic and processor time dedicated for that…
Use map folder on your HD that will contain all maps used for current project that is visible to all machines and if everything is setup right you wouldn’t have any problem at all.
