DR bug... and others
hey, im not sure if this have been posted before, i rendered this images and slaved about 3 other machines, all the blocks that my machine rendered were darker than the others but only on a specific material… to fix it i removed the material and relinked a new one.
is that a bug or is it something to do with the type of material???
after fixing it i still got some splotchyness on the cieling, this is with mado settings and Hsps subdivs on 80… so im not sure what setting will smooth it out
Re: DR bug… and others
Changing the one material fixed it? It was a linked material? Is there anyway you could send me the scene that yielded the incorrect buckets? Or do you have anyway to let me know how to reproduce it? Thanks
I have encountered the same problem, it seems that when using sun system with distributed rendering not all of the information is passed to the slave machine(s) and you get the result shown in your render. I look forward to seeing a fix for this in the near future.
how did you do the floor, i like it
