DR can't connect to servers - OS error 10061
I’m trying to process a large resolution image with DR in 3ds Max 2025 with Vray 7 Update 4. Servers have the spawner open with the same version of 3ds Max, but the log shows this error:
Warning : Server (server ip): OS error 10061; connection refused.
The image does process locally and when including local host, it works, but none of the servers connect.
Please make sure you are using the correct port for Distributed Rendering.
Does it work properly when rendering at a smaller resolution?
Could you also try a simpler scene?
Even a simple scene with a higher resolution and enough samples to take a few minutes to render would be helpful.
Also, check the memory usage on the render nodes while rendering. It could be memory-related, especially if the workstation has more memory available.
If you are still having issues, send us the log file, and we can take a look.
Let us know how it goes.
Thank you!
Are you using the DR2 version of V-Ray? If you do, here’s what fixed it for me:
  1. Right click on the shortcut of the V-Ray GPU spawner on your desktop and click on “Properties”.
  2. In the “Target:” field change “-portNumber=20206” to “-portNumber=20209”
  3. Click “OK” to save the changes and restart the GPU spawner
I hope this helps!
