Hello ![]()
Using Max 2017 and Vray 3.60.03
I know this gets asked a lot but I’m not sure what else to try anymore. Basically have 5 vray and 1 Phoenix workstation licenses and 35 render node licenses. All machines connected on the same domain and all machines/render nodes work fine on Backburner.
DR works on a handful of machines (the rest just show as connection timeout) I have set the windows firewall to accept the default DR port 20204. Tried forwarding the port on some machines that dont work in the router but still not working.
The DHCP and DNS server runs on a windows server 2008 machine. Just wondering if this could be the issue?
Otherwise all machines can talk to each other and access network files etc and render fine via backburner just will not work on DR.
We have a wibu key dongle and the license server is on the same Windows server as above.
Any help would be appreciated.
*Forgot to say all the render nodes are just using the spawner ran as admin and not registered as a service.
