DR in VIZ 2006
I’m trying to get DR working in VIZ 2006 with 1.47. I’ve read as many posts on this as I can find. I’ve replaced the dummy max and xml files with new ones that I created with VIZ several times. Spawner starts and then crashes. Does anyone have any tips?
Refer to Vlado’s reply in this thread:
http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=13997
nikki Candelero
make a new xml (start with a new scene …just put a plane and a camera and also use scanline…send it to the backburner and copy the file located under backburner(server machine). it worked for me and i had teh same problem.
one more thing…use 1.46.15, as you should know…1.47.xx has a bug
http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=11640
Thanks flino I’ve tried this and it’s not working. I dont have 1.46.15 for 2006. I requested it yesterday but havn’t heard back from chaos. Mabye some one could email it to me ar325ar@aol.com. Thanks
flino - does that bug only affect VIZ 2006? I am using VIZ 2005 & Vray 1.47.30 and DR is working fine.
arobbert -Did you try re-installing your Vray on all of your slave comps and server? I seem to remember doing that but I don’t think it was because I was trying to fix a DR problem. Sorry that seems vague. Can’t hurt I guess.
Regards Peter.
Yes I reinstalled. Right noe I’m just trying to get spawner to run on a couple computers, thanks for the idea though.
What’s your OS? I had a similar problem and found that 2006 doesn’t work on Windows Server 2000 like 2005 did.
XP pro.
