DR Issue
Hi i’m having an issue where my render is ‘finishing’ even though it’s clearly not finished.
It’s set to 3% noise value. Part of the image -say the bottom 8th’ looks fine, the rest is super noisy. In the stats window it says its at 2.19% even though it’s only done 8 combined passes on DR
Are you using 1.7 hf2 or the latest daily build? There are issues with noise limit and DR in the daily builds, but 1.7 should work fine.
All 1.7hf2
Can you please send us all DR logs? Here is how to collect them: https://coronarenderer.freshdesk.com/support/solutions/articles/12000002065
Other than that, you can check what exactly your nodes are sending (and maybe that would give us a clue why one part of the image is clear and the rest is not). Here is more info about this: https://coronarenderer.freshdesk.com/support/solutions/articles/12000002064
