Hello, following the change of my internet router, the DR no longer works. Slave PCs are no longer recognized … do you have a solution to this problem? thank you in advance.
Thx
yanosh
If the issue appeared after changing the router, then it most probably isn’t related to Corona. Do other network-related tasks work fine, like sharing files between the PCs?
You can try resetting router settings to factory defaults.
Maybe some firewall/AV application or the internal firewall of the router is blocking the connection?
Thank you for your answer … I take note …
it turns out that only one of my two slaves is not recognized. I will look for that side.
thank you Maru
The best idea will be probably to think about any differences you can spot between the problematic node and the other ones - software, hardware, network connection,…
