DR Issue
Hello
I am using two slaves for DR, all workstations use Corona 3-hotfix 1 and Max 2017.
For some reason one of the slaves seems to brighten the image once it starts sending passes, any idea why this is? It only occurs on one slave, not the other.
It’s usually caused by a missing asset, e.g. a texture file usually, though could be a proxy or some model or an xref.
Can check into some troubleshooting:
https://coronarenderer.freshdesk.com/support/solutions/articles/12000002048-missing-maps-assets-drserver-is-running-with-elevated-uac-rights-as-administrator-
You can also save the EXRs sent from the slaves with the checkbox, and check to see what that individual slave’s output looked like, should pin down what object is to blame. Hope this helps!
EDIT - the link to all DR troubleshooting articles:
https://coronarenderer.freshdesk.com/support/solutions/folders/12000000629
