The ability to kill a render node while rendering out a sequence in case we encounter errors while rendering on a particular node. The rest of the machines will continue out onto the next frames while leaving a specified machine out. Granted, that particular frame will be effected.
Is that for Backburner or for DR rendering?
Vray DR - not sure if this can be an option selectable from the Vray Frame Buffer…
The ability to Kill and add DR nodes would be great Just like BB but in DR..
Some times when I’m doing a DR a bucket will ‘fail’. The host workstation will just keep waiting indefinately for the bucket, even though the client has been disconnected. It would be good to have the ability to ‘zap’ a render node from the list and have that bucket processed by another client. As it stands at the moment, if this occurs a re-render of the frame is required.
Cheers.
-- DJ
