Hi guys, we just test that the dr doesnt recognize network map folders or network folders, only local on server machines, this also apply to bitmaps and proxys, havent tested with xref scenes yet. hope it helps
The DR just launches 3dsmax as if you would do so locally. Seach for file “received_scene.max” in the DrServer location on the slave. Try opening and rendering it - does it render with textures? If not, you may need to set up the asset paths in 3dsmax to make it work.
we have done this already, the problem its with the files that are alocatted on the server, we have 5 machines and one server with all the textures so all the machines have virtual mapped disks calling the server, all with the same name path, the dr doesnt find them, no textures, no proxys (that work as textures or referenced files).
Ok, so this is a personal network problem? because thats the path for the slave, the main computer doesnt says found, any ideas how to fix this?
but thats the strange thing, it does, all the slaves have the same paths exactly
ok, my knowledge of asset tracking is limited, but from the discussion it looks like 3dsmax problem
I had the same issue - even though all my slaves would show the correct path and status as ‘Network Path’, during render the bitmaps wouldn’t show.
Resolving all paths to UNC Location did the trick.
Asset Tracking (Shift + T) - Right click → Resolve Path to UNC Location.
Hope it helps.
