Hi folks,
This one has us stumped, still.
We have 4 machines here all running on the same switch. I control 3 of them and my colleague controls 1 of them. All 3 of my machines render perfectly with both BB and DR rendering together. Maps are read fine and rendering works 100%.
We’re trying to get DR renders to launch from his machine and use one of mine as a DR node.
I can use my colleague’s machine as a DR slave when the render is launched from mine and everything renders perfectly. Maps are transferred properly.
However my colleague’s machine refuses to send any maps across the network for DR rendering when the render is launched from his own machine. For BB rendering they transfer just fine. In fact, it’s not only maps from his machine but mine too. If he renders a scene on his machine with maps from my machine (UNC all the way, of course) it still doesn’t work. So map location is irrelevant, it seems. His machine simply won’t transfer any maps of any sort from any location to or from his machine when he is the one to launch the render.
His machine works with maps perfectly over BB. It’s literally only DR that doesn’t work.
Here’s the error from my the DRServer log when his machine has sent the render:
Required asset file(s) could not be located:
We have tried with different files. If we use a map that’s actually on my own machine (via UNC path) it still doesn’t work. My machine cannot get access to a map on my own machine, when the render is launched from his machine. It’s very bizarre.
That exact UNC path resolves perfectly on my own machine. I have full read and write permissions on that shared folder. I can view the map just fine. If I load the same max file myself and use HIS machine as a DR node, it works. The map is transferred.
Same max version, same corona version (inc. DR server) - we’re on the dailies from 20th with DR from 17th, UNC paths that properly resolve on both machines. The only obvious thing that’s different is that he’s on windows 7 pro and I’m on 8.1 pro. Maybe there’s an issue there somewhere?
Totally stumped! We think it must be some kind of network/permissions/ports issue but can’t think why…
