DR node not working
Hey guys,
Just having an issue with getting a workstation (whilst my colleague is away) to join in rendering an animation sequence I’ve got going. I currently have two render nodes already working on it with no problems at all, but this workstation doesn’t seem to want to work.
On my workstation/host machine it appears to join, but then shows up as not responding. I’ve checked the VRay Log for that machine and this is all it does:
[2015/Apr/14|08:50:48] ============================================================
[2015/Apr/14|08:50:48] Console created, V-Ray A for x64 from Dec 5 2014, 22:56:49
[2015/Apr/14|08:50:48] Compiled with Intel C++ compiler, version 14
[2015/Apr/14|08:50:48] Host is 3dsmax, version 17
[2015/Apr/14|08:50:48] V-Ray DLL version is 3.10.01
[2015/Apr/14|08:50:51] Constructor entered.
[2015/Apr/14|08:50:51] Setting default filter kernel.
[2015/Apr/14|08:50:51] “default” preset not loaded: Cannot open file “C:\Users\nigelcook\AppData\Local\Autodesk\3dsMaxDesign\2015 - 64bit\ENU\en-US\plugcfg\vray.cfg”
[2015/Apr/14|08:50:51] Constructor done.
[2015/Apr/14|08:50:51] Resetting VRender.
[2015/Apr/14|08:51:08] Broadcasting TM_SERVER_STARTED after start up
[2015/Apr/14|08:51:08] Received TM_START_RENDER from 10.0.0.139
[2015/Apr/14|08:51:08] Starting DR session from 10.0.0.139
[2015/Apr/14|08:51:08] Receiving DR scene from 10.0.0.139
[2015/Apr/14|08:51:17] Resetting VRender.
[2015/Apr/14|08:51:17] Setting default filter kernel.
[2015/Apr/14|08:51:17] “default” preset not loaded: Cannot open file “C:\Users\nigelcook\AppData\Local\Autodesk\3dsMaxDesign\2015 - 64bit\ENU\en-US\plugcfg\vray.cfg”
[2015/Apr/14|08:51:18] Constructor entered (loading from file).
[2015/Apr/14|08:51:18] Setting default filter kernel.
[2015/Apr/14|08:51:18] “default” preset not loaded: Cannot open file “C:\Users\nigelcook\AppData\Local\Autodesk\3dsMaxDesign\2015 - 64bit\ENU\en-US\plugcfg\vray.cfg”
[2015/Apr/14|08:51:18] Constructor done.
[2015/Apr/14|08:51:18] Loading from file.
[2015/Apr/14|08:51:18] Loading filter parameters.
[2015/Apr/14|08:51:18] Adding host “10.0.0.194”:20204 from scene
[2015/Apr/14|08:51:18] Adding host “10.0.0.229”:20204 from scene
[2015/Apr/14|08:51:18] Adding host “10.0.0.236”:20204 from scene
[2015/Apr/14|08:51:18] Loading done.
[2015/Apr/14|08:51:18] Constructor entered.
[2015/Apr/14|08:51:18] VRenderer destructor entered.
[2015/Apr/14|08:51:18] VRenderer destructor done.
[2015/Apr/14|08:51:25] Scene loaded from “C:\Users\nigelcook\AppData\Local\Autodesk\3dsMaxDesign\2015 - 64bit\ENU\temp\vray_server_scene.max”
Then it crashes/stops/restarts and repeats the process over and over again.
First try to update to the latest version and make sure, that all machines have the same version of V-Ray /3.10.03/ and let us know if the problem still persist.
