DR node Ping timeout
rendering irradiance map on DR with 2 Q6600 i’m experiencing this problem:
both pc partecipate to DR on frames #0 - 2, in the middle of 2 spawner buckets disappear and irrmap rendering uses only 1 pc.
so i try restarting manually slave spawner and this is what i get:
warning: Render host unknown (ip) is not responding
Render host (ip) added
Ping not received from host 0.0.0.0 for 610453 milliseconds, dropping connection.
any idea for? thanx for any reply
Check the vraylog.txt file on that machine, perhaps it can tell something useful.
hi vlado.
i had to reboot and decrease irradiance map size to solve, so vraylog has been cleared.
checking spawner log i found following:
0: [2009/May/29|07:21:05] ========================== Starting new session ==========================
1: [2009/May/29|07:21:05] Got this module name: C:\Program Files\Autodesk\3ds Max 2009\vrayspawner2009.exe
2: [2009/May/29|07:21:05] Got this INI file name: C:\Program Files\Autodesk\3ds Max 2009\VRaySpawner.ini
3: [2009/May/29|07:21:05] *** ALERT! Could not open INI file: “C:\Program Files\Autodesk\3ds Max 2009\VRaySpawner.ini”. Using defaults.
4: [2009/May/29|07:21:05] --
5: [2009/May/29|07:21:05] Dumping current settings…
6: [2009/May/29|07:21:05] VRaySpawner temp dir: “C:\Program Files\Autodesk\3ds Max 2009\network”
7: [2009/May/29|07:21:05] Application name (MAX/VIZ): “C:\Program Files\Autodesk\3ds Max 2009\3dsmax.exe”
8: [2009/May/29|07:21:05] --
9: [2009/May/29|07:21:05] Process id is 2268 (0x8dc)
10: [2009/May/29|07:21:05] Executing ““C:\Program Files\Autodesk\3ds Max 2009\3dsmax.exe” -server C:\Program Files\Autodesk\3ds Max 2009\network\vraydummy2009.max”
11: [2009/May/29|07:37:46] ========================== Ending session ==========================
sounds familiar?
EDIT: both pc use XP64
