Corona 1.0.max 2015. I have problems with the DR. In principle it had on A7,2))) After the DR based rendering with max on the auxiliary car crashes with a warning. And while this warning is not closed, the next job starts. Ie DR is not running.
Could you show a screenshot of this warning?
Here are some articles on DR that might help:
https://coronarenderer.freshdesk.com/support/solutions/articles/5000501666
https://coronarenderer.freshdesk.com/support/solutions/articles/5000570043
https://coronarenderer.freshdesk.com/support/solutions/articles/5000568996
https://coronarenderer.freshdesk.com/support/solutions/articles/5000539776
Any success?
This does not happen regularly. Put 1.01. Watch. By the way what is the difference version 1 and 1.01?
difference between 1 and 1.00.01 is just cosmetic (1 still shows “corona alpha” in renderstamp). Can you click on the “more details” on the last line in the error report with green arrows (I assume it is named same as in english) and post the screenshot?
Just a random idea - all winows updates installed?
https://coronarenderer.freshdesk.com/support/solutions/articles/5000501938
the error message is “The service did not respond to the start or control request in a timely fashion.”… this is really weird. Can you try to produce a minidump? See https://coronarenderer.freshdesk.com/support/solutions/articles/5000524006 - “2. Reporting Error Messages”
Sent minidump
