DR port through firewall
Does anyone know what port Vray uses for DR? I think I need to open it up through the firewalls. How do you guys deal with this… Everything works fine if the firewalls are disabled on the render servers.
Thanks,
B
I would say its more likely to be the licence server its blocking. Can you render normally on those PC’s? with the firwalls up.
Personally I think software firewalls a pretty pointsless especially when your behind a router.. your on a local subnet so pretty protected right there.
All that being said the DR port is 20204 AFAIK try that.
