DR problem after install 3.30.3
I have installed 3.30.3 and the DR slaves only render the first time… after this don’t render… i never have this problem with previous installations of VRay
Thx in advance…
2 Workstation’s (1 in XP with 32 GB Ram and other in Windows 7 with 12 GB Ram)
4 Rendernodes in XP with 32 Gb Ram
hmm can you paste a log from slaves? did you try checking restart dr servers on render end?
Hi Dmitry.. thx in advance for the help
The option “restart dr servers on render end” is always on. I test “Use Embree” on and off and no effect.
I’m doing some tests. If start the DR from the W7 workstation the other machines do the render (1 XP Workstation+4 XP rendernodes) . If i do it from de XP Workstation, the other machines only do the first render… after that they do nothing . If i restart 3ds Max they render the first render again… sometimes not all machines.. very strange.. i never had this issues…
0: [2015/Dec/28|20:14:14] ========================== Starting new session ==========================
1: [2015/Dec/28|20:14:14] Got this module name: C:\Program Files\Autodesk\3ds Max 2013\vrayspawner2013.exe
2: [2015/Dec/28|20:14:14] Got this INI file name: C:\Program Files\Autodesk\3ds Max 2013\VRaySpawner.ini
3: [2015/Dec/28|20:14:14] *** ALERT! Could not open INI file: “C:\Program Files\Autodesk\3ds Max 2013\VRaySpawner.ini”. Using defaults.
4: [2015/Dec/28|20:14:14] Dumping current settings…
5: [2015/Dec/28|20:14:14] VRaySpawner temp dir: “C:\Users\afreitas\AppData\Local\Temp”
6: [2015/Dec/28|20:14:14] Application name (MAX/VIZ): “C:\Program Files\Autodesk\3ds Max 2013\3dsmax.exe”
7: [2015/Dec/28|20:14:14] Listening port(s): default
8: [2015/Dec/28|20:14:14] --
9: [2015/Dec/28|20:14:14] System configuration:
10: [2015/Dec/28|20:14:14] Group aware processor detection:
11: [2015/Dec/28|20:14:14] Processor group 0
12: [2015/Dec/28|20:14:14] NUMA node 0, mask 0xFF, used: true
13: [2015/Dec/28|20:14:14] --
14: [2015/Dec/28|20:14:14] Using system default affinity
15: [2015/Dec/28|20:14:14] Process id is 8048 (0x1f70)
16: [2015/Dec/28|20:14:14] Executing "“C:\Program Files\Autodesk\3ds Max 2013\3dsmax.exe” -server C:\Users\afreitas\AppData\Local\Temp\vraydummy2013.max "
0: [2015/Dec/29|10:35:46] ========================== Starting new session ==========================
1: [2015/Dec/29|10:35:46] Got this module name: C:\Program Files\Autodesk\3ds Max 2013\vrayspawner2013.exe
2: [2015/Dec/29|10:35:46] Got this INI file name: C:\Program Files\Autodesk\3ds Max 2013\VRaySpawner.ini
3: [2015/Dec/29|10:35:46] *** ALERT! Could not open INI file: “C:\Program Files\Autodesk\3ds Max 2013\VRaySpawner.ini”. Using defaults.
4: [2015/Dec/29|10:35:46] Dumping current settings…
5: [2015/Dec/29|10:35:46] VRaySpawner temp dir: “C:\Users\afreitas\AppData\Local\Temp”
6: [2015/Dec/29|10:35:46] Application name (MAX/VIZ): “C:\Program Files\Autodesk\3ds Max 2013\3dsmax.exe”
7: [2015/Dec/29|10:35:46] Listening port(s): default
8: [2015/Dec/29|10:35:46] --
9: [2015/Dec/29|10:35:46] System configuration:
10: [2015/Dec/29|10:35:46] Group aware processor detection:
11: [2015/Dec/29|10:35:46] Processor group 0
12: [2015/Dec/29|10:35:46] NUMA node 0, mask 0xFF, used: true
13: [2015/Dec/29|10:35:46] --
14: [2015/Dec/29|10:35:46] Using system default affinity
15: [2015/Dec/29|10:35:46] Process id is 4340 (0x10f4)
16: [2015/Dec/29|10:35:46] Executing "“C:\Program Files\Autodesk\3ds Max 2013\3dsmax.exe” -server C:\Users\afreitas\AppData\Local\Temp\vraydummy2013.max "
17: [2015/Dec/29|11:37:35] Process id is 4340 (0x10f4)
18: [2015/Dec/29|11:37:35] Executing "“C:\Program Files\Autodesk\3ds Max 2013\3dsmax.exe” -server C:\Users\afreitas\AppData\Local\Temp\vraydummy2013.max "
19: [2015/Dec/29|18:28:33] ========================== Ending session ==========================
0: [2015/Dec/29|19:03:12] ========================== Starting new session ==========================
1: [2015/Dec/29|19:03:12] Got this module name: C:\Program Files\Autodesk\3ds Max 2013\vrayspawner2013.exe
2: [2015/Dec/29|19:03:12] Got this INI file name: C:\Program Files\Autodesk\3ds Max 2013\VRaySpawner.ini
3: [2015/Dec/29|19:03:12] *** ALERT! Could not open INI file: “C:\Program Files\Autodesk\3ds Max 2013\VRaySpawner.ini”. Using defaults.
4: [2015/Dec/29|19:03:12] Dumping current settings…
5: [2015/Dec/29|19:03:12] VRaySpawner temp dir: “C:\Users\afreitas\AppData\Local\Temp”
6: [2015/Dec/29|19:03:12] Application name (MAX/VIZ): “C:\Program Files\Autodesk\3ds Max 2013\3dsmax.exe”
7: [2015/Dec/29|19:03:12] Listening port(s): default
8: [2015/Dec/29|19:03:12] --
9: [2015/Dec/29|19:03:12] System configuration:
10: [2015/Dec/29|19:03:12] Group aware processor detection:
11: [2015/Dec/29|19:03:12] Processor group 0
12: [2015/Dec/29|19:03:12] NUMA node 0, mask 0xFF, used: true
13: [2015/Dec/29|19:03:12] --
14: [2015/Dec/29|19:03:12] Using system default affinity
15: [2015/Dec/29|19:03:12] Process id is 4244 (0x1094)
16: [2015/Dec/29|19:03:12] Executing "“C:\Program Files\Autodesk\3ds Max 2013\3dsmax.exe” -server C:\Users\afreitas\AppData\Local\Temp\vraydummy2013.max "
17: [2015/Dec/29|19:13:26] Process id is 4244 (0x1094)
18: [2015/Dec/29|19:13:26] Executing "“C:\Program Files\Autodesk\3ds Max 2013\3dsmax.exe” -server C:\Users\afreitas\AppData\Local\Temp\vraydummy2013.max "
19: [2015/Dec/29|19:27:38] Process id is 4244 (0x1094)
20: [2015/Dec/29|19:27:38] Executing "“C:\Program Files\Autodesk\3ds Max 2013\3dsmax.exe” -server C:\Users\afreitas\AppData\Local\Temp\vraydummy2013.max "
Can you reproduce the issue on a simple scene? Do you use the same V-Ray version on all machines?
Hi Zdravko,
All machines have 3.30.3 (i have already reinstall in the 2 workstation’s and reinstall licence server).
The problem happen with old scenes (haven after reset vray to default settings) and with new one (1 teapot instanced 100x100, one vray camera and une vray sun)
Any news please…
We’ll need a bit more information - can you send me the file vraylog.txt from the slave machines to vlado@chaosgroup.com ? The file should be in the temporary folder of the current user (you can go there by typing %temp% in Windows Explorer).
Hi Vlado,
Mail sent…
Thx
Hy! News on this?
It’s been a year since the initial post and there are quite a few new V-Ray versions since then.
Would you please confirm that the issue is still there with the latest 3.40.03 version?
