Hi everyone, i sarched on forum but i cant find other tread about my problem.
if there is other discussion sorry in advantege.
i have problem with dr on backburner on animation, i have 3dsmax 2021 and corona 6, when i start a job first frame work perfectly, all node receve scene and start to work, but at second frame all node stop on downloading scene and dont contribute to work…
thank you
Nicola
this is a node DRlog:
2020-10-05 17:25:41 Running command:
“C:\Program Files\Autodesk\3ds Max 2021\3dsmaxcmd.exe” “C:\Users\utente\AppData\Local\CoronaRenderer\DrData\corona_dr.max” -continueOnError -gammaCorrection:1 -rfw:1 -sf -v:5 -postRenderScript:“C:\Users\utente\AppData\Local\CoronaRenderer\DrData\post.ms”
2020-10-05 17:25:46 Started loopback connection with 3ds max
2020-10-05 17:25:47 Cannot contact 3ds Max, trying again …
2020-10-05 17:25:47 3dsMax started successfully
2020-10-05 17:25:47 Accepted remote connection from 192.168.1.71
2020-10-05 17:25:47 Started connection 25
2020-10-05 17:25:47 Handshake: 0init3Max2021CoronaCamera0010 0 0 01500 15006192.168.1.71
2020-10-05 17:25:47 Saving incoming scene to C:/Users/utente/AppData/Local/CoronaRenderer/DrData/received_scene_2476406284.max
2020-10-05 17:25:48 Received sampling focus mask (region 0 0 1500 1500)
this is coronamax log:
2020-10-05 17:25:33 This scene uses legacy (pre-v4) medium/refraction resolving that is not based on geometry normals and produces incorrect results when multiple medium containers are intersecting. The scene was loaded with the legacy behavior to make the rendered result more consistent with older versions of Corona, but we strongly recommend switching to new behavior using the button below. If normals orientation is correct, switching will preserve or improve the look of the scene.
2020-10-05 17:25:33 Disabling ‘max sample intensity’ or setting it to high values can cause fireflies to appear in the image that will never go away.
2020-10-05 17:25:46 Bound to localhost.
2020-10-05 17:25:46 Sending handshake to DrServer.
2020-10-05 17:25:46 Heartbeat socket opened.
2020-10-05 17:25:46 Local connection with DrSlave established.
2020-10-05 17:26:05 This scene uses legacy (pre-v4) medium/refraction resolving that is not based on geometry normals and produces incorrect results when multiple medium containers are intersecting. The scene was loaded with the legacy behavior to make the rendered result more consistent with older versions of Corona, but we strongly recommend switching to new behavior using the button below. If normals orientation is correct, switching will preserve or improve the look of the scene.
2020-10-05 17:26:06 Disabling ‘max sample intensity’ or setting it to high values can cause fireflies to appear in the image that will never go away.
2020-10-05 17:26:06 DR slave started waiting loop
2020-10-05 17:26:06 DR slave received sampling mask, region 0 0 1500 1500
