DR problem with Cor 3.0
have a problem with new corona 3.0 (also with hotfix1)… have two pcs, one master second slave, after parsing the scene on second it just stops in one second and then back in the loop… then i got back to cor 2.0 and its working… have no idea why, tried all the possible settings from network, firewall etc… i saw a similiar post earlier and tried the solutions from that post but still not working…
best regards
Luka
Is it the same as here? https://forum.corona-renderer.com/ DR Server not picking up
Thanks for reply… yes its the same problem… but my second pc transfer almost whole scene, vram like 8gb…
i tried installing all versions from 2.0 till 3.0 hot fix… what i didnt tried is the last point of you - 4) Remove all files in this folder C:\Users\Marcin\AppData\Local\CoronaRenderer\DrData… maybe that will help…
any other ideas?
Yes, please try the suggestions I listed here (including removing the files), and let me know if it helped or not:
https://forum.corona-renderer.com/ DR Server not picking up #msg141459
