it seems that DR is not working with objects that are animated using script controllers or parameter wiring, can anyone confirm that ? If i hide BOTH the objects AND the rig (assorted dummies and splines) to get DR to work.
Sorry should have explained in more detail on first try.
The local buckets render just fine. The DR slaves are responding in the log, the get the scene sent and then they say “Scene Loaded starting render” but they never respond with “Starting frame xx” and simply stall. So the scene renders locally only
