I’m having 32 flavours of trouble getting DG going on our network and am after a little help.
I think I’m on top of DRWizard50 and have it setup correctly on each of my render boxes.
My question really lies with the Vraynet.ini.
With the new spawner the VRaynet.ini doesn’t contain any of that.
Delete the file and set up DR with the wiz again.
Also, make sure you set up locals dirs on each slave for the temp dir, not a network share, since that will:
1. be slower
2. cause all DR slaves to overwrite the same temp file causing a bunch of problems in the process.
Someone could explain it? write a “DR for dummies”, sell it, and make millions!
I dont have clear wich dirs have to point to the client machine trough the network, where to put the plugins to have them in all the machines, etc
