Hi I m using Corona lastest build 1.6 27 March, But Bug was allready there in previus 1.6 beta.
Main Machine XEON 2973V4 64 Go Windows 10, Render Node XEON 2973V4 48 Go Windows 10.
On a random basis, can’t figure out how to have the bug, The node get stuck on a Stripe to render, And not contributing on the whole Image.
It is very annoying because the node doesn’t allway contribute to the full render, and render passe go cray 1500 pass after 8 min…
See attached image.
I have no Render Region (Max of VFB) activated, and take special care to disable every region.
Too bad the DR log contains only data since 2017/03/30. I don’t see any problems there, I suspect the problem happened before that?
Did you check the images that slaves render? Is it indeed the same strip every time, or does the slave render just black images for other strips?
Sorry for Logs, I have reinstalled many time Corona (news builds), and it seems to erase every time the log file. Or juste to escessive on Purging Temps File on node HArd Drive.
Yes It did happend before, on a pure random basis.
The slave render only a Stripe (a very noise free Stripe…) and every thing else is pure black.
I think I notice tjat the stripe moves everytime, from bottom to too, By the increment on the pixel height… CAn be sure, because, I didnt take time to analyse, but I can enable retain EXR to figure out if it is.
I have 4 renders to run today, I will take attention to those. and get back to you.
Thanks for the images. I seems the DR behaves as expected. Each node only renders a strip constrained by the “Max pixel to transfer at once” parameter and when it sends the results over to master, it moves to the next strip. If you want to get the dumps from slaves faster, increase the pixels per transfer, or decrease the synchronization interval.
