DR; Render Slave returns no work..
I use distributed rendering on two slaves. The first machine churns away happily, the other loads the scene and then returns “Render Completed” shortly after without doing any work. :face_with_spiral_eyes:
Any ideas what could be wrong?
Specs on both machines;
xp sp3
max 2009 sp1
vray sp3
i had this exact bug once.
i closed 3ds max, and started it again.
the bug was gone…
I am having the same problem. Please help!
Since I upgraded to SP3a, only two of my nodes will participate in DR. The others say immediately come back with “Render completed” and obviously do not join in.
I have logged into each node, restarted the service, rebooted the machine, etc., nothing helps. Its always the same nodes that don’t work, i.e. Nodes 1 through 6 will not participate, nodes 7 and 8 always work.
They all worked fine with SP2.
I really would like to use all my nodes for DR. Any ideas?
My workstation and all nodes:
XP 64
Max 2009 sp1
Vray 1.5 sp3a
Thanks in advance,
Aaron
Additionally, after the node says “Render completed” a while later the vray messages say “Ping not received from host x.x.x.x for 603125 milliseconds, dropping connection” and then " warning: Render host x is not respinding"
I pinged the node in question, and it responded fine… What’s going on here?
All nodes are working, because they show up in backburner and render frames just fine.
I have this only if u use Vray license service for DR (on every node), if I use Vray license server ( on every node) all work perfect.
Not sure I understand the difference of what you are saying. I have vrayspawner running as a service on each machine, and a central license server that they all point to. I have all the licenses on one dongle.
This setup worked fine with SP2. I shouldn’t have to change it. Plus, all nodes see the license server when rendering frames via BB.
I suspected it might be a license issue though… thanks! Vlado? Is this a bug?
You are right about my upper post, I was thinking about spawner not license server.. :slight_smile:
On every machine chaos group → DR → Launch V-Ray DR spawner
not DR → Administration → Register V-Ray spawner service
Agreed this was fine in SP2.
Well, if thats the case, I’m going back to SP2!
But, why do 2 nodes work fine, but not the rest? I would expect all nodes to fail the same way…
I fixed the above problem. The nodes that were not responding properly were older nodes with an old version of Vray installed: for 2008 and 2009. And when installing SP3a, after it uninstalled sp2, and then installed SP3a, it said it could not remove all files. So I uninstalled 2008, un-installed Vray spawner 2009 as a service, then re-installed. Now DR and all nodes work fine.
I will have to try this and report back. I’m having the exact same issue and just found this post.
OK I uninstalled directly from the Control Panel → Add/Remove Programs and then re-installed vray 1.5 sp3a and now my 2 slaves I tested did DR with no problems at all.
Initially, I had done the same thing as Clifton, I let the updated installer uninstall the old version and I guess it left some piece of it behind. On another note, when I uninstalled it from one of the machines, it still said I would have to manually remove some files, but once it was re-installed DR worked fine.
Now if I can only figure out the Win7 issue I’m having at home! LOL!
Thanks, Clifton for the suggestion.
