DR render slave search not working
Something happened, and now the host cannot find render slaves anymore.
I start render slaves as administrator, I tried with a7, and now a7.1 but still have that problem, the main pc can’t find slaves automatically like it used in a6.
When I type in the IPs manually, the DR works, but I get weird “building acc. structure” on the render slaves and it just keeps building… nothing is rendering. The weird thing is, if I just use 1 slave, it gets stuck a bit on building acc. structure and then starts rendering in about 2 minutes..
This is a bit frustrating, because I finally decided to do a project for my client with corona instead of vray, and I get this error, now I have to convert all the stuff back to vray if I cannot fix it… not sure why this happening.
Okay, “Building acc. Structure” was caused by vrayHDRI map, as soon as I removed it, it renders fine!
The DR works fine too, but I have to type in the IPs manually, wonder why the automatic search cannot see the slaves anymore. But I am happy I can move on with Corona for this project!
Fixed! by using wired connection, disabled wireless.
