It keeps failing. It works in default scanline when I choose split scan lines in the network job assignment in backburner. I selct DR in vray systems and then I have tried it with both cheking off split frame in the backburner and without it checked on and both times in fails.
You cannot use DR in jobs being rendered through backburner.
dr rendering problem using 1.47 vray and max 8 with backburn
what do you use if not backburner? I do have spawner running in the background.
Re: dr rendering problem using 1.47 vray and max 8 with back
Just regular rendering.
ok, that worked. I was turning on nework rendering in MAX, which was taking me to backburner.
