Why i cant render without bucket errors, dark etc…
Which is the best way to dr?..bucket mode?..
Do i have also to point trough the materials-bitmaps slot to a network location, or I’ve just have to set up the slave computer through the paths to the network location?
Thanks in advance!
Make sure all of your bitmaps are located in one folder accessible to all computers on your network. The paths should be set using UNC not drive letters.
Ok, maybe is me but..i used the UNC mode trough the material-bitmap loader of the main computer… but the slave cant see the bitmaps!..
Please help me !..
Thanks in advance
Bitmap path
You need set up bitmap path for each max to all computers and run spawner after it, only.
I usually use the bitmap/photometric path editor utility so you can see all your paths at once.
