I’m having an odd problem when at the stage “gathering remaining data from slaves”. The render just seems to keep going. It completes the 90 required passes, now 15min later it’s still gathering remaining data and is at 157 passes…
ok, I will add more info to the error message and we will debug the problem together. Can we continue on skype? If yes, can you send me your screen name in PM?
I have encounterd this when i had 2 distant nodes and had to use VPN connection to fake local area connection. I found out that lowering default settings fixes it. I usualy used numbers like 3sec sinc interval na vax 50k pixels to transfer at once.
I will close this as it is too old, but if you experience it with 1.4 please let us know. There is now improved errror reporting, so it should point you to a file you should send us
Hey Ondra, I think I figured out the cause of this. When rendering a 5000px image between 26 slaves, i currently have DR setup so it can only transfer 50,000px every 15sec. I noticed that after it had reached the pass limit, these 50,000px .exrs were still being generated by the slaves (up to 200 of them) to send to the master and because it could only transfer every 15sec, it seemed like it was taking forever.
I will test again some time today with the default pixel amount and see if that doesn’t solve the problem.
