Hey, im trying to ge drserver to work but despite putting my Login details into the text file in the right place it still refuses to get the license. Any ideas?
Jack
Jack
Hi, have you seen our helpdesk DR article?
https://coronarenderer.freshdesk.com/support/solutions/articles/5000501666
Also, this:
https://forum.corona-renderer.com/index.php/topic,8543.0.html
If you already tried some of the suggested solutions, please submit a support ticket and describe your problem in detail:
https://coronarenderer.freshdesk.com/support/tickets/new
I have tried yes, its on a hp blade server that we already use with backburner so theres no problem there. It accepts the ping and it is displayed in the list in corona but when i check the log it says it cant find the license. ill submit a ticket.
Jack
I suggest ti use the CoronaLicensingServer for the clients, i had this problem also a few times.
Now it works like a charm.
When install Corona select the License Server on the Install for the Main Workstation.
here’s a Guide to set this up: https://coronarenderer.freshdesk.com/support/solutions/articles/5000618553-corona-licensing-server
Works perfectly thanks. getting dark strips on my renders though but im sure i spotted something in the FAQ about that so ill take a look ![]()
