I’m trying to use distributed rendering with several machines, but i’m getting low memory usage in each machine (screenshot attached).
I can’t figure out the problem ![]()
Hi, the DR server uses only memory needed for the current scene to be rendered by 3ds Max + Corona. There’s no advantage in using more RAM. Is there some reason to expect that the reported memory usage is lower than it actually should be?
