When wifi turned on : dr server binding connection to my wifi ip adress and it works but downloding scene is extremely long.
when wifi turned off on : dr server binding to my lan ip as i need
how can i fix it? i need working wifi on my slave and dr server works only by lan not wifi?
Here’s log when wifi on:
2020-10-11 19:28:42 Binding UDP socket to local address 169.254.74.120 (its lan ip)
2020-10-11 19:28:42 Binding UDP socket to local address 10.0.1.11 (its wifi IP)
2020-10-11 19:28:42 Running Corona DrServer build Sep 25 2020 on TCP/UDP ports 19666, loopback TCP/UDP19667
2020-10-11 19:28:42 Available 3dsmax versions:
2020-10-11 19:28:42 2020: C:/Program Files/Autodesk/3ds Max 2020/
2020-10-11 19:28:42 Running command:
“C:\Program Files\Autodesk\3ds Max 2020\3dsmaxcmd.exe” “C:\Users\shoom\AppData\Local\CoronaRenderer\DrData\corona_dr.max” -continueOnError -gammaCorrection:1 -rfw:1 -sf -v:5 -postRenderScript:“C:\Users\shoom\AppData\Local\CoronaRenderer\DrData\post.ms”
2020-10-11 19:28:43 Started loopback connection with 3ds max
2020-10-11 19:28:44 Cannot contact 3ds Max, trying again …
2020-10-11 19:28:44 3dsMax started successfully
2020-10-11 19:28:52 Accepted remote connection from 169.254.161.237
2020-10-11 19:28:52 Started connection 1
PS.sorry for my english
