I have a fk***** scene, its bad, i was using corona 1.1, and now testing 1.3 rc3-rc5, and dr is not working now, slaves rebot the proces after parsing scene state… and i dont know about the reflection on the nearest glass… were can i attach the wetransfer scene (kind of NDA)…
Two ideas for the parsing:
- FTH: https://coronarenderer.freshdesk.com/support/solutions/articles/5000678431
- Some other user reported that a similar problem went away after converting all the bitmaps to CoronaBitmap. This can be done using this script: https://coronarenderer.freshdesk.com/support/solutions/articles/5000549705
The spots on the door look like a bug.
You can send the scene via wetransfer or similar here https://coronarenderer.freshdesk.com/support/tickets/new .
Thx maru, i filled the ticket, the corona bitmap didnt work…and the FTH is more for speed problems?
the slaves go trough the parsing scene, but after is finiched it restarts 3dmax and start from 0 …
note to self: bud dr parsing.zip
Have you tried setting 3dsmax process priority to low on slave once it starts up? We will be re-introducing that in 1.3, similarproblems were fixed by it
Will try that tomorrow, ant reply, is it reproducible on your side?
no, I was unable to reproduce any problems here…
Solved on 1.3 public version
THX!
