We’ve got 2 render-slaves and 3 workstations newly set up with win7 prof. x64 and 3ds max 2012.
I was in hope to get all slaves to render a specific scene together in DR mode. So far so good…or not.
The 2 render-slaves rendered fine and one older workstation (wk05) as well with the job-assigning workstation. One workstation (wk03) still keeps starting/restarting the DRspawner.
May it be possible that the assigning wk (wk04) cannot communicate with ‘wk03’? Is there maybe a hardware config errorness of the inbuilt network-controllers?
Thanks for your suggestions; this is driving me nuts.
Ok; try to do a regular backburner render with those machines as render slaves. The first time it runs, it does some setup for backburner, which is apparently needed later on for the spawner to work successfully.
