DR & stats
Is there particular reason why DR tab stats woudn’t be updated ? our nodes are actually rendering, but the DR stats keep on showing Updates:0 Passes:0 … it’s the first time I see that ! any idea, please ?
Thanks,
Regards.
The nodes are rendering and their passes are submitted to the final image, or they are just rendering and their output is not forward to the master?
It could be some kind of communication problem. Could you share your full DR logs? https://coronarenderer.freshdesk.com/support/solutions/articles/12000002065
Hi Maru,
THanks for your feedback. However, I suspect it’s bound to this [https://forum.corona-renderer.com/ ***WARNING*** CORONA ERROR: DR error: Accumulating EXR from slave
](https://forum.corona-renderer.com/ ***WARNING*** CORONA ERROR: DR error: Accumulating EXR from slave ), with resolution changed afterwards through BB job settings … I’m going to run another test now, just to check.
Confirmed - I’ve just tried again, with setting the correct resolution initially in the 3dsmax file (and not by changing it from the BB job settings), no more problem !! :wink:
I’ve posted that also in the other thread, please feel don’t hesitate to remove this one.
