the other two people’s machines work in the office, but mine suddenly stopped working.
I can run vray spawner just fine. Just when rendering the hosts fail.
I thought it was my file so I created a new scene with just a few boxes, applied a vray material and gave it some reflections so it would take long enough to even need to distribute.
Here’s the part of the log:
[2005/Dec/7|08:34:21] Irradiance sample size is 84 bytes
[2005/Dec/7|08:34:21] Photon size is 56 bytes.
[2005/Dec/7|08:34:21] Broadcasting NOTIFY_PRE_RENDERFRAME.
[2005/Dec/7|08:34:21] beginFrame() done.
[2005/Dec/7|08:34:21] Broadcasting NOTIFY_BEGIN_RENDERING_ACTUAL_FRAME.
[2005/Dec/7|08:34:21] Setting up DoneCallback.
[2005/Dec/7|08:34:21] Rendering frame region (0,0)-(3000,3000).
[2005/Dec/7|08:34:21] Lightmap sample size is 72 bytes.
[2005/Dec/7|08:34:21] Rendering image.
[2005/Dec/7|08:34:21] Setting up 4 thread(s)
[2005/Dec/7|08:34:26] warning: Render host 169.254.210.10 failed
[2005/Dec/7|08:34:31] warning: Render host 169.254.124.20 failed
[2005/Dec/7|08:34:36] warning: Render host 169.254.67.11 failed
[2005/Dec/7|08:34:41] warning: Render host 169.254.67.12 failed
[2005/Dec/7|08:34:46] warning: Render host 169.254.67.13 failed
[2005/Dec/7|08:34:51] warning: Render host 169.254.67.14 failed
[2005/Dec/7|08:34:53] Threads completed
[2005/Dec/7|08:34:53] Calling endFrame().
[2005/Dec/7|08:34:53] Entering endFrame().
[2005/Dec/7|08:34:53] Broadcasting NOTIFY_POST_RENDERFRAME.
[2005/Dec/7|08:34:53] Applying render effects.
[2005/Dec/7|08:34:53] Number of raycasts: 3694001
[2005/Dec/7|08:34:53] Waiting for DR to finish
That doesn’t seem to tell me Anything, but it might to one of you experts out there.
Everything seems to be set up just fine. I recently installed the egzMaterials. That was the only thing I could think of. I removed the folder in the scripts, but the messages above are after removing that.
Any ideas?
