i’m facing a problem while setting a new node for DR.
It seems to work fine, but is very slow.
My workstation 01 is a AMD TR 2990wx @ 4ghz
The new workstation 02 is a dual xeon ES 2698v4 @ 2ghz
While rendering, 01 makes 11 passes when 02 update 25 time and render 2 passes.
I use Pulze SM to manage this.
Usage on 02 is 95% cpu, 50% RAM…
All connected with a modem router.
Also, as you can see the name of 02 is pretty weird, I didnt put that…! Can’t change it, it keeps changing back.
Any idea ? Thx !
maru
September 23, 2020, 3:40pm
2
Hi, can you see how it works without Pulze? (not blaming the software for anything, just trying to rule out possible issues!)
So could you try with Corona’s DR only, or with Backburner only?
If the scene is very heavy, the process of sending it to the node and then starting up can take quite a lot of time as well. So maybe you just need to allow some more time for the node to heat up before it reaches its peak speed?
Hey !
I will try without Pulze sure !
After reinstalling evrything, DR still dont begin and DRlog give me this :
020-09-23 17:47:55 DR server started
2020-09-23 17:47:55 Binded to localhost
2020-09-23 17:47:55 Binding UDP socket to local address 192.168.5.100
2020-09-23 17:47:55 Running Corona DrServer build Aug 31 2020 on TCP/UDP ports 19666, loopback TCP/UDP19667
2020-09-23 17:47:55 Available 3dsmax versions:
2020-09-23 17:47:55 2020: C:/Program Files/Autodesk/3ds Max 2020/
2020-09-23 17:47:55 Running command:
“C:\Program Files\Autodesk\3ds Max 2020\3dsmaxcmd.exe” “C:\Users\WS04\AppData\Local\CoronaRenderer\DrData\corona_dr.max” -continueOnError -gammaCorrection:1 -rfw:1 -sf -v:5 -postRenderScript:“C:\Users\WS04\AppData\Local\CoronaRenderer\DrData\post.ms”
2020-09-23 17:47:56 Started loopback connection with 3ds max
2020-09-23 17:47:57 Cannot contact 3ds Max, trying again …
2020-09-23 17:47:57 3dsMax started successfully
2020-09-23 17:47:58 Accepted remote connection from 192.168.5.90
2020-09-23 17:47:58 Started connection 1
2020-09-23 17:47:58 Handshake: 0init0Max2020PDV bas0 0 0 02500 18751125db10ad05e07eb35a5232455234da6192.168.5.90
2020-09-23 17:47:58 Saving incoming scene to C:/Users/WS04/AppData/Local/CoronaRenderer/DrData/received_scene_4132660861.max
2020-09-23 17:47:59 Downloaded scene: 103 M bytes in 0 s
2020-09-23 17:47:59 Render for connection 1 started
2020-09-23 17:48:00 Received sampling focus mask (region 0 0 2500 1875)
2020-09-23 17:48:50 Closing loopback manager
2020-09-23 17:48:50 DR is finished
2020-09-23 17:48:50 Ready for new connection
2020-09-23 17:48:50 Running command:
2020-09-23 17:48:52 Started loopback connection with 3ds max
2020-09-23 17:48:53 Cannot contact 3ds Max, trying again …
2020-09-23 17:48:53 3dsMax started successfully
2020-09-23 17:48:53 Accepted remote connection from 192.168.5.90
2020-09-23 17:48:53 Started connection 2
2020-09-23 17:48:53 Handshake: 0init0Max2020PDV bas0 0 0 02500 18751125db10ad05e07eb35a5232455234da6192.168.5.90
2020-09-23 17:48:53 Saving incoming scene to C:/Users/WS04/AppData/Local/CoronaRenderer/DrData/received_scene_1643554016.max
2020-09-23 17:48:54 Downloaded scene: 103 M bytes in 0 s
2020-09-23 17:48:55 Received sampling focus mask (region 0 0 2500 1875)
2020-09-23 17:48:55 Render for connection 2 started
2020-09-23 17:49:46 Closing loopback manager
2020-09-23 17:51:40 DR is finished
2020-09-23 17:51:40 Ready for new connection
2020-09-23 17:51:40 Running command:
2020-09-23 17:51:42 Started loopback connection with 3ds max
2020-09-23 17:51:43 Cannot contact 3ds Max, trying again …
2020-09-23 17:51:43 3dsMax started successfully
2020-09-23 18:22:22 Replying to discovery ping from 192.168.5.90
2020-09-23 18:23:00 Accepted remote connection from 192.168.5.90
2020-09-23 18:23:00 Started connection #3
2020-09-23 18:23:00 Handshake: 0init0Max2020PDV bas0 0 0 02500 1875525033e30a177fa4d97790a60d71737c6192.168.5.90
2020-09-23 18:23:00 Saving incoming scene to C:/Users/WS04/AppData/Local/CoronaRenderer/DrData/received_scene_1223492519.max
2020-09-23 18:23:00 Downloaded scene: 103 M bytes in 0 s
2020-09-23 18:23:01 Render for connection #3 started
2020-09-23 18:23:09 Closing loopback manager
2020-09-23 18:23:10 DR is finished
2020-09-23 18:23:10 Ready for new connection
2020-09-23 18:23:10 Running command:
2020-09-23 18:23:12 Started loopback connection with 3ds max
2020-09-23 18:23:13 Cannot contact 3ds Max, trying again …
2020-09-23 18:23:13 3dsMax started successfully
2020-09-23 18:23:13 Accepted remote connection from 192.168.5.90
2020-09-23 18:23:13 Started connection 4
2020-09-23 18:23:13 Handshake: 0init0Max2020PDV bas0 0 0 02500 1875525033e30a177fa4d97790a60d71737c6192.168.5.90
2020-09-23 18:23:13 Saving incoming scene to C:/Users/WS04/AppData/Local/CoronaRenderer/DrData/received_scene_2888573702.max
2020-09-23 18:23:14 Downloaded scene: 103 M bytes in 0 s
2020-09-23 18:23:15 Render for connection 4 started
2020-09-23 18:23:37 Received sampling focus mask (region 0 0 2500 1875)
2020-09-23 18:24:06 Closing loopback manager
2020-09-23 18:24:06 DR is finished
2020-09-23 18:24:06 Ready for new connection
2020-09-23 18:24:06 Running command:
2020-09-23 18:24:08 Started loopback connection with 3ds max
2020-09-23 18:24:09 Cannot contact 3ds Max, trying again …
2020-09-23 18:24:09 3dsMax started successfully
2020-09-23 18:24:09 Accepted remote connection from 192.168.5.90
2020-09-23 18:24:09 Started connection 5
2020-09-23 18:24:09 Handshake: 0init0Max2020PDV bas0 0 0 02500 1875525033e30a177fa4d97790a60d71737c6192.168.5.90
2020-09-23 18:24:09 Saving incoming scene to C:/Users/WS04/AppData/Local/CoronaRenderer/DrData/received_scene_2437811417.max
2020-09-23 18:24:10 Downloaded scene: 103 M bytes in 0 s
2020-09-23 18:24:11 Render for connection 5 started
2020-09-23 18:24:11 Received sampling focus mask (region 0 0 2500 1875)
2020-09-23 18:25:13 Closing loopback manager
2020-09-23 18:25:13 DR is finished
2020-09-23 18:25:13 Ready for new connection
2020-09-23 18:25:13 Running command:
2020-09-23 18:25:15 Started loopback connection with 3ds max
2020-09-23 18:25:16 Cannot contact 3ds Max, trying again …
2020-09-23 18:25:16 3dsMax started successfully
2020-09-23 18:25:16 Accepted remote connection from 192.168.5.90
2020-09-23 18:25:16 Started connection 6
2020-09-23 18:25:16 Handshake: 0init0Max2020PDV bas0 0 0 02500 1875525033e30a177fa4d97790a60d71737c6192.168.5.90
2020-09-23 18:25:16 Saving incoming scene to C:/Users/WS04/AppData/Local/CoronaRenderer/DrData/received_scene_2628383657.max
2020-09-23 18:25:17 Downloaded scene: 103 M bytes in 0 s
2020-09-23 18:25:18 Received sampling focus mask (region 0 0 2500 1875)
2020-09-23 18:25:18 Render for connection 6 started
I think there is a pb with the render region activated in Pulze, but I cant get ride of it even when no region is selected in VFB…
I tryed everything told in help desk for “Closed Loopback Connection”…
In the VFB I’m still getting “Connexion failed” then “Cannot send message” then it turns red and start over to “downloading scene”, “parsing” …
On W10 on both workstations, all is good and detected, ping ok, licence ok, I can access to shared folders…
I’m missing smthg…
Frood
September 24, 2020, 6:56am
5
Have you had a look at max.log of one of the failing slaves?
Good Luck
No, only to the DRlog… cf copy in the 3rd post
For the last hours, same problem :
2020/09/24 02:18:28 DBG: [07636] [14092] Starting network
2020/09/24 02:18:28 INF: [07636] [14092] Application started with secure mode state ‘OFF’
2020/09/24 02:18:28 INF: [07636] [14092] Product version: 3ds Max 2020.3 Update (22.3.0.3165)
2020/09/24 02:18:28 DBG: [07636] [14092] ADP Initialize: Done
2020/09/24 02:18:28 INF: [07636] [14092] Data collection and use is ‘OFF’. Change your participation anytime in the Help menu of 3ds Max.
2020/09/24 02:18:30 DBG: [07636] [14092] Could not find the specified file in DefaultSettingsParser::parse()
2020/09/24 02:18:39 DBG: [07636] [14092] Graphics driver requested by the user : Nitrous
2020/09/24 02:18:39 DBG: [07636] [14092] Graphics driver actually created in the viewports : null driver
2020/09/24 02:18:44 INF: [07636] [14092] Autodesk 3ds Max Security Tools is active via configuration settings
2020/09/24 02:18:44 INF: [07636] [14092] ALC Security Tool 1.0 loaded. (c:\program files\autodesk\3ds max 2020\applicationplugins\securitytools\contents\scripts\ALC_SecurityTool.ms)
2020/09/24 02:18:44 INF: [07636] [14092] CRP Security Tool 1.0 loaded. (c:\program files\autodesk\3ds max 2020\applicationplugins\securitytools\contents\scripts\CRP_SecurityTool.ms)
2020/09/24 02:18:44 INF: [07636] [14092] ADSL Security Tool 1.0 loaded. (c:\program files\autodesk\3ds max 2020\applicationplugins\securitytools\contents\scripts\ADSL_SecurityTool.ms)
2020/09/24 02:18:52 DBG: [07636] [14092] Starting network
2020/09/24 02:19:08 DBG: [07636] [14092] Calling NetRenderPreLoad
2020/09/24 02:19:08 DBG: [07636] [14092] in NetWorkerPreLoad. jobFile: C:\Users\WS04\AppData\Local\Temp\corona_dr__10856_16604609.xml; jobname: C:\Users\WS04\AppData\Local\CoronaRenderer\DrData\corona_dr.max
2020/09/24 02:19:08 DBG: [07636] [14092] in Init. jobFile: C:\Users\WS04\AppData\Local\Temp\corona_dr__10856_16604609.xml; jobname: C:\Users\WS04\AppData\Local\CoronaRenderer\DrData\corona_dr.max
2020/09/24 02:19:08 DBG: [07636] [14092] in Init. calling nrGetIface. jobToSend: C:\Users\WS04\AppData\Local\CoronaRenderer\DrData\corona_dr.max job:C:\Users\WS04\AppData\Local\Temp\corona_dr__10856_16604609.xml
2020/09/24 02:19:08 DBG: [07636] [14092] in NetWorkerPreLoad. curJobname: C:\Users\WS04\AppData\Local\CoronaRenderer\DrData\corona_dr.max; init: 0
2020/09/24 02:19:08 DBG: [07636] [14092] in NetWorkerPreLoad. calling PostInitMessageSystem()
2020/09/24 02:19:08 DBG: [07636] [14092] in NetWorkerPreLoad. srv_pid: 10856
2020/09/24 02:19:08 DBG: [07636] [14092] leaving NetWorkerPreLoad. LoadLib()
2020/09/24 02:19:08 DBG: [07636] [14092] NetRenderPreLoad passed
2020/09/24 02:19:08 DBG: [07636] [14092] Graphics driver requested by the user : Nitrous
2020/09/24 02:19:08 DBG: [07636] [14092] Graphics driver actually created in the viewports : null driver
2020/09/24 02:19:19 DBG: [07636] [14092] Interface8::LoadFromFile(C:\Users\WS04\AppData\Local\CoronaRenderer\DrData\corona_dr.max)
2020/09/24 02:19:19 INF: [07636] [14092] Starting to load file: C:\Users\WS04\AppData\Local\CoronaRenderer\DrData\corona_dr.max
2020/09/24 02:19:20 INF: [07636] [14092] SYSTEM: Production renderer is changed to Scanline Renderer. Previous messages are cleared.
2020/09/24 02:19:20 INF: [07636] [14092] CORONA: Corona is up and running. Corona version: 6, netrender mode: on, slave mode: on, quiet mode: on, Max gamma (display/input/output): 2.2000000476837158/2.2000000476837158/2.2000000476837158
2020/09/24 02:19:20 INF: [07636] [14092] CORONA : This scene uses legacy (pre-v4) medium/refraction resolving that is not based on geometry normals and produces incorrect results when multiple medium containers are intersecting. The scene was loaded with the legacy behavior to make the rendered result more consistent with older versions of Corona, but we strongly recommend switching to new behavior using the button below. If normals …
2020/09/24 02:19:20 INF: [07636] [14092] Done loading file: C:\Users\WS04\AppData\Local\CoronaRenderer\DrData\corona_dr.max
2020/09/24 02:19:20 INF: [07636] [14092] SYSTEM: Production renderer is changed to Corona 6. Previous messages are cleared.
2020/09/24 02:19:20 INF: [07636] [14092] Starting network rendering
2020/09/24 02:19:20 INF: [07636] [14092] Max is ready to begin render
2020/09/24 02:19:21 INF: [07636] [14092] Frame 0 assigned
2020/09/24 02:19:21 INF: [07636] [14092] Frame started at: 02:19:21
2020/09/24 02:19:21 INF: [07636] [14092] BEGIN FRAME 0; TASK 1 OF 1; (NO SAVE);
2020/09/24 02:19:21 ERR: [07636] [14092] Render failed
2020/09/24 02:19:21 INF: [07636] [14092] END FRAME 0; TASK 1 OF 1; (NO SAVE); 0.094s; 0 faces; MEM 769 MB;
2020/09/24 02:19:21 ERR: [07636] [14092] Render Error (Render Frame)
2020/09/24 02:19:21 DBG: [07636] [14092] Interface8::LoadFromFile(C:\Users\WS04\AppData\Local\CoronaRenderer\DrData\received_scene_2813093526.max)
2020/09/24 02:19:21 INF: [07636] [14092] Starting to load file: C:\Users\WS04\AppData\Local\CoronaRenderer\DrData\received_scene_2813093526.max
2020/09/24 02:19:31 WRN: [07636] [14092] Missing dll: vraycolor2020.dlt - VRayColor
2020/09/24 02:19:31 WRN: [07636] [14092] Missing dll: vrender2020.dlr - VRayMtl
2020/09/24 02:19:31 WRN: [07636] [14092] Missing dll: vrender2020.dlr - VRayDiffuseFilterMap
2020/09/24 02:19:31 WRN: [07636] [14092] Missing dll: psdmanager.dlv - psdmanagerRELayer
2020/09/24 02:19:31 WRN: [07636] [14092] Missing dll: psdmanager.dlv - psd-manager
2020/09/24 02:19:32 WRN: [07636] [14092] MAXScript FileIn Exception: – Unknown system exception
2020/09/24 02:19:32 ERR: [07636] [14092] Error executing script
2020/09/24 02:19:34 DBG: [07636] [14092] Stop network
2020/09/24 02:19:42 DBG: [14640] [12700] Starting network
2020/09/24 02:19:42 INF: [14640] [12700] Application started with secure mode state ‘OFF’
2020/09/24 02:19:42 INF: [14640] [12700] Product version: 3ds Max 2020.3 Update (22.3.0.3165)
2020/09/24 02:19:42 DBG: [14640] [12700] ADP Initialize: Done
2020/09/24 02:19:42 INF: [14640] [12700] Data collection and use is ‘OFF’. Change your participation anytime in the Help menu of 3ds Max.
2020/09/24 02:19:42 DBG: [14640] [12700] Could not find the specified file in DefaultSettingsParser::parse()
2020/09/24 02:19:47 DBG: [14640] [12700] Graphics driver requested by the user : Nitrous
2020/09/24 02:19:47 DBG: [14640] [12700] Graphics driver actually created in the viewports : null driver
2020/09/24 10:36:36 DBG: [07768] [13980] Starting network
2020/09/24 10:36:36 INF: [07768] [13980] Application started with secure mode state ‘OFF’
2020/09/24 10:36:36 INF: [07768] [13980] Product version: 3ds Max 2020.3 Update (22.3.0.3165)
2020/09/24 10:36:36 DBG: [07768] [13980] ADP Initialize: Done
2020/09/24 10:36:36 INF: [07768] [13980] Data collection and use is ‘OFF’. Change your participation anytime in the Help menu of 3ds Max.
2020/09/24 10:36:37 DBG: [07768] [13980] Could not find the specified file in DefaultSettingsParser::parse()
2020/09/24 10:36:47 DBG: [07768] [13980] Graphics driver requested by the user : Nitrous
2020/09/24 10:36:47 DBG: [07768] [13980] Graphics driver actually created in the viewports : null driver
2020/09/24 10:36:52 INF: [07768] [13980] Autodesk 3ds Max Security Tools is active via configuration settings
2020/09/24 10:36:52 INF: [07768] [13980] ALC Security Tool 1.0 loaded. (c:\program files\autodesk\3ds max 2020\applicationplugins\securitytools\contents\scripts\ALC_SecurityTool.ms)
2020/09/24 10:36:52 INF: [07768] [13980] CRP Security Tool 1.0 loaded. (c:\program files\autodesk\3ds max 2020\applicationplugins\securitytools\contents\scripts\CRP_SecurityTool.ms)
2020/09/24 10:36:52 INF: [07768] [13980] ADSL Security Tool 1.0 loaded. (c:\program files\autodesk\3ds max 2020\applicationplugins\securitytools\contents\scripts\ADSL_SecurityTool.ms)
2020/09/24 10:37:01 DBG: [07768] [13980] Starting network
2020/09/24 10:37:26 DBG: [07768] [13980] Calling NetRenderPreLoad
2020/09/24 10:37:26 DBG: [07768] [13980] in NetWorkerPreLoad. jobFile: C:\Users\WS04\AppData\Local\Temp\corona_dr__12444_46492546.xml; jobname: C:\Users\WS04\AppData\Local\CoronaRenderer\DrData\corona_dr.max
2020/09/24 10:37:26 DBG: [07768] [13980] in Init. jobFile: C:\Users\WS04\AppData\Local\Temp\corona_dr__12444_46492546.xml; jobname: C:\Users\WS04\AppData\Local\CoronaRenderer\DrData\corona_dr.max
2020/09/24 10:37:26 DBG: [07768] [13980] in Init. calling nrGetIface. jobToSend: C:\Users\WS04\AppData\Local\CoronaRenderer\DrData\corona_dr.max job:C:\Users\WS04\AppData\Local\Temp\corona_dr__12444_46492546.xml
2020/09/24 10:37:26 DBG: [07768] [13980] in NetWorkerPreLoad. curJobname: C:\Users\WS04\AppData\Local\CoronaRenderer\DrData\corona_dr.max; init: 0
2020/09/24 10:37:26 DBG: [07768] [13980] in NetWorkerPreLoad. calling PostInitMessageSystem()
2020/09/24 10:37:26 DBG: [07768] [13980] in NetWorkerPreLoad. srv_pid: 12444
2020/09/24 10:37:26 DBG: [07768] [13980] leaving NetWorkerPreLoad. LoadLib()
2020/09/24 10:37:26 DBG: [07768] [13980] NetRenderPreLoad passed
2020/09/24 10:37:26 DBG: [07768] [13980] Graphics driver requested by the user : Nitrous
2020/09/24 10:37:26 DBG: [07768] [13980] Graphics driver actually created in the viewports : null driver
2020/09/24 10:37:37 DBG: [07768] [13980] Interface8::LoadFromFile(C:\Users\WS04\AppData\Local\CoronaRenderer\DrData\corona_dr.max)
2020/09/24 10:37:37 INF: [07768] [13980] Starting to load file: C:\Users\WS04\AppData\Local\CoronaRenderer\DrData\corona_dr.max
2020/09/24 10:37:38 INF: [07768] [13980] SYSTEM: Production renderer is changed to Scanline Renderer. Previous messages are cleared.
2020/09/24 10:37:38 INF: [07768] [13980] CORONA: Corona is up and running. Corona version: 6, netrender mode: on, slave mode: on, quiet mode: on, Max gamma (display/input/output): 2.2000000476837158/2.2000000476837158/2.2000000476837158
2020/09/24 10:37:38 INF: [07768] [13980] CORONA : This scene uses legacy (pre-v4) medium/refraction resolving that is not based on geometry normals and produces incorrect results when multiple medium containers are intersecting. The scene was loaded with the legacy behavior to make the rendered result more consistent with older versions of Corona, but we strongly recommend switching to new behavior using the button below. If normals …
2020/09/24 10:37:38 INF: [07768] [13980] Done loading file: C:\Users\WS04\AppData\Local\CoronaRenderer\DrData\corona_dr.max
2020/09/24 10:37:38 INF: [07768] [13980] SYSTEM: Production renderer is changed to Corona 6. Previous messages are cleared.
2020/09/24 10:37:38 INF: [07768] [13980] Starting network rendering
2020/09/24 10:37:38 INF: [07768] [13980] Max is ready to begin render
2020/09/24 10:37:39 INF: [07768] [13980] Frame 0 assigned
2020/09/24 10:37:39 INF: [07768] [13980] Frame started at: 10:37:39
2020/09/24 10:37:39 INF: [07768] [13980] BEGIN FRAME 0; TASK 1 OF 1; (NO SAVE);
2020/09/24 10:37:39 ERR: [07768] [13980] Render failed
2020/09/24 10:37:39 INF: [07768] [13980] END FRAME 0; TASK 1 OF 1; (NO SAVE); 0.094s; 0 faces; MEM 780 MB;
2020/09/24 10:37:39 ERR: [07768] [13980] Render Error (Render Frame)
2020/09/24 10:37:40 DBG: [07768] [13980] Interface8::LoadFromFile(C:\Users\WS04\AppData\Local\CoronaRenderer\DrData\received_scene_4021995225.max)
2020/09/24 10:37:40 INF: [07768] [13980] Starting to load file: C:\Users\WS04\AppData\Local\CoronaRenderer\DrData\received_scene_4021995225.max
2020/09/24 10:37:50 WRN: [07768] [13980] Missing dll: vraycolor2020.dlt - VRayColor
2020/09/24 10:37:50 WRN: [07768] [13980] Missing dll: vrender2020.dlr - VRayMtl
2020/09/24 10:37:50 WRN: [07768] [13980] Missing dll: vrender2020.dlr - VRayDiffuseFilterMap
2020/09/24 10:37:50 WRN: [07768] [13980] Missing dll: psdmanager.dlv - psdmanagerRELayer
2020/09/24 10:37:50 WRN: [07768] [13980] Missing dll: psdmanager.dlv - psd-manager
2020/09/24 10:37:50 WRN: [07768] [13980] MAXScript FileIn Exception: – Unknown system exception
2020/09/24 10:37:50 ERR: [07768] [13980] Error executing script
2020/09/24 10:37:52 DBG: [07768] [13980] Stop network
2020/09/24 10:38:00 DBG: [13716] [09000] Starting network
2020/09/24 10:38:00 INF: [13716] [09000] Application started with secure mode state ‘OFF’
2020/09/24 10:38:00 INF: [13716] [09000] Product version: 3ds Max 2020.3 Update (22.3.0.3165)
2020/09/24 10:38:00 DBG: [13716] [09000] ADP Initialize: Done
2020/09/24 10:38:00 INF: [13716] [09000] Data collection and use is ‘OFF’. Change your participation anytime in the Help menu of 3ds Max.
2020/09/24 10:38:01 DBG: [13716] [09000] Could not find the specified file in DefaultSettingsParser::parse()
2020/09/24 10:38:06 DBG: [13716] [09000] Graphics driver requested by the user : Nitrous
2020/09/24 10:38:06 DBG: [13716] [09000] Graphics driver actually created in the viewports : null driver
Frood
September 24, 2020, 9:03am
8
This one is that annoying bug introduced in v5 when using dr server for the first time after starting it, usual.
But here might be your problem. I suspect psd-manager is missing and any script maybe related to it throws an error. I’m not familiar with psd-manager but I suspect it has to be installed on all participating nodes which seems not to be the case.
Good Luck
Frood:
Good Luck
Thanks !
Well, I saw that and installed Vray demo + copied PSDmanager file as told on the cebas website, but doesnt seems to resolve anything…
I also get this when 3ds starts with DR server on the node…
This might sound like a strange fix, but if you have your view locked in the 3ds max render setup I recommend to unlock and relock the view, save the scene and try to render with DR again.
Let me know how you get on.
Cheers,
Rowan
Not block, but I try with and without to test…
maru
September 24, 2020, 3:30pm
14
I was also counting on the “lock icon fix”…
Here are some more ideas:
Do you have the same plugins installed on both computers, and the same versions?
Do you have Backburner installed on both computers?
Do you have any non-Latin characters in your Windows username, asset names, paths?
Are you able to open the scene locally on both computers, and successfully start local rendering? (locally, without any kind of network rendering involved)
The maxscript error can be fixed by increasing the maxscript heap allocation size, here is how:
See point 2 “Set Maxscript…”:
https://coronarenderer.freshdesk.com/support/solutions/articles/12000019416
Other than that:
(sorry if some of that is repeated)
Disable any antivirus software you are using on all PCs (including Windows Defender and Firewall) - this is just to check if the issue is related to this software. You can then turn it back on.
Open your scene, go to Render Setup, deselect the small “lock” icon in the top right corner. Click on any viewport, then click on the viewport you want to render again. Enable the “lock” icon in the top right corner of the Render Setup window again. Resave your scene. Unlocking and locking viewport like this sometimes helps with DR issues.
Refresh the 3ds Max ENU folder by either renaming or removing it. Note that this will remove all your custom ui settings, keyboard shortcuts, etc, so it is best to leave a backup of the ENU folder.
See: https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/sfdcarticles/sfdcarticles/Resetting-3ds-Max-3ds-Max-Design.html
If the above 3 points did not help, here are some other ones worth trying:
Add custom inbound/outbound rules in Windows Firewall.
See: Creating custom inbound and outbound rules for the DR Server application
Are you using some VPN software? If so, please stop using it and make sure you are using BB/DR on a “classic” local network.
Do not mix Corona’s DR and Backburner. Use only one or the other.
Make sure on each computer there is only one instance of: 3ds Max, DR server, Backburner. If there are multiple instances running at the same time (for example two 3dsmax.exe processes), some issues may appear.
Do not render from perspective view - use some kind of camera, preferably Corona Camera.
Disable IPv6.
See: https://medium.com/@JockDaRock/disabling-ipv6-on-network-adapter-windows-10-5fad010bca75
Go to Windows Services list and make sure “Function Discovery Provider Host” and “Function Discovery Resource Publication” are started. Set them to automatic start.
Make sure you have network discovery enabled.
See: Turn On or Off Network Discovery and File Sharing on Windows 11/10
Wow I will try all of this when I’m back, this weekend !
Thanks, keep in touch!
After trying almost all your list of tips, I couldnt open the file properly on the slave… and discovered the pb !
I knew this was a stupid noob problem ^^
As the slave is not connected to internet, I had to update Max version to 2020.3 manually, and forgot to install first 2020.1 and .2 …
Everything rune fine now thanks for the assistance !!
Regards,
JG
maru
September 29, 2020, 3:25pm
18
So all of that was because on one PC you had Max 2020.1 and on the other one 2020.3? That’s crazy. But also an important point we will need to add to our troubleshooting guides.
