I’m getting the error in the title and just don’t know what to check anymore:
I have this setup:
A linux server where the vray license server is running.
5 Imac’s with maya and vray installed
1 of those is my workstation from where I start jobs which have DR enabled,
I have added the other four (static) ip’s in the maya DR settings list.
1 of the machines (192.168.1.12) always gives the above error, one of the others ( 192.168.1.18 ) sometimes.. the other two never give any errors. I can ping all the machines from my workstation.
On every machine vray.exe is running, i pointed to the license server correctly..
Sometimes i get black blocks in my render, but other times not..
on every machine i enabled, wake on lan if they are asleep, actually i even disabled sleep..
when I batch render I can see in the log that vray starts using 3 hosts for DR, but then during rendering irradiance or light cache, some of the hosts won’t respond anymore and the render fails..(blocks..)
hmmm… it appeared our license server stopped working, when i checked the status page of the license server the DR licenses were maxed out at 10 but we only have 4 hosts.
when we tried to restart the license server it appeared that 2 deamons were running??
Message from syslogd@chef at Oct 15 15:31:17 …
kernel:[366300.746265] Oops: 0002 [4] SMP
kernel:[366300.746339] last sysfs file: /sys/devices/pci0000:00/0000:00:1d.7/usb2/2-2/2-2.4/idVendor
chef:/home/raro#
kernel:[366300.748965] Stack:
kernel:[366300.749460] Call Trace:
