I hesitate at even making another troubled DR post, but I can’t seem to find any other threads with a similar condition.
I’m testing with a simple scene of just a field of teapots, no maps… when rendering DR will kick in and contribute to the IRR calc, and write out to file, but then when it flips to rendering the DR nodes can’t load the irr, the message log is says that it’s sending XXXX bytes of the irr map to the rendernode, but it never starts rendering.
Additionally the irr map it helps to write out is clean, I can render with IRR from file cleanly on the local machine, but again the DR node never kicks in to help.
anyone have any ideas? below is what I’m finding in the log files…
VrayLog.txt.server seems to point at the problem when if goes to render, but I don’t know what to do about.
[2008/Feb/11|09:50:54] Broadcasting NOTIFY_BEGIN_RENDERING_ACTUAL_FRAME.
[2008/Feb/11|09:50:54] Photon size is 56 bytes.
[2008/Feb/11|09:50:54] Light cache sample size is 120 bytes.
[2008/Feb/11|09:50:54] 1 interpolation maps registered
[2008/Feb/11|09:50:54] Rendering interpolation maps with minRate=-3 and maxRate=0
[2008/Feb/11|09:50:54] Setting up 8 thread(s)
[2008/Feb/11|09:50:56] 11 % completed.
[2008/Feb/11|09:51:31] Threads completed
[2008/Feb/11|09:51:31] Calling endPass() on irradiance maps
[2008/Feb/11|09:51:31] Calling prePassDone() on irradiance maps
[2008/Feb/11|09:51:31] Image prepass completed.
[2008/Feb/11|09:52:21] warning: Error receiving irradiance map 0
[2008/Feb/11|09:52:21] Rendering image.
[2008/Feb/11|09:52:21] Setting up 8 thread(s)
[2008/Feb/11|09:53:11] Threads completed
[2008/Feb/11|09:53:11] Entering endFrame().
[2008/Feb/11|09:53:11] Broadcasting NOTIFY_POST_RENDERFRAME.
[2008/Feb/11|09:53:11] Applying render effects.
[2008/Feb/11|09:53:11] Number of raycasts: 35340059
[2008/Feb/11|09:53:11] Clearing global light manager.
[2008/Feb/11|09:53:11] Clearing direct light manager.
[2008/Feb/11|09:53:11] Clearing ray server.
[2008/Feb/11|09:53:11] Clearing geometry.
[2008/Feb/11|09:53:11] Calling frameEnd() on render instances.
[2008/Feb/11|09:53:11] Calling frameEnd() on render objects.
[2008/Feb/11|09:53:11] Calling frameEnd() on render materials.
[2008/Feb/11|09:53:11] Clearing camera image sampler.
[2008/Feb/11|09:53:11] Clearing camera sampler.
[2008/Feb/11|09:53:11] Clearing QMC sampler.
[2008/Feb/11|09:53:11] Clearing path sampler.
[2008/Feb/11|09:53:11] Clearing color mapper.
[2008/Feb/11|09:53:11] Region rendering: 136.3 s
[2008/Feb/11|09:53:11] endFrame() done
[2008/Feb/11|09:53:11] Entering endSequence().
[2008/Feb/11|09:53:11] Calling renderEnd().
[2008/Feb/11|09:53:11] Calling renderEnd() on render materials.
[2008/Feb/11|09:53:11] Sending RenderEnd().
[2008/Feb/11|09:53:11] Sending RenderEnd() to atmospheric effects.
[2008/Feb/11|09:53:11] Sending RenderEnd() to render effects.
[2008/Feb/11|09:53:11] Sending RenderEnd() to the tone operator.
[2008/Feb/11|09:53:11] Sending RenderEnd() to environment maps.
[2008/Feb/11|09:53:11] Unloading bitmaps.
[2008/Feb/11|09:53:11] Freeing render instances and lights.
[2008/Feb/11|09:53:11] Broadcasting NOTIFY_POST_RENDER.
[2008/Feb/11|09:53:11] endSequence() finished.
as for the VRspawner.txt everything looks normak (i think)
0: [2008/Feb/11|09:19:38] ========================== Starting new session ==========================
1: [2008/Feb/11|09:19:38] Got this module name: C:\Program Files\Autodesk\3ds Max 2008\vrayspawner90.exe
2: [2008/Feb/11|09:19:38] Got this INI file name: C:\Program Files\Autodesk\3ds Max 2008\VRaySpawner.ini
3: [2008/Feb/11|09:19:38] Reading settings from INI file: “C:\Program Files\Autodesk\3ds Max 2008\VRaySpawner.ini”
4: [2008/Feb/11|09:19:38] --
5: [2008/Feb/11|09:19:38] Dumping current settings…
6: [2008/Feb/11|09:19:38] VRaySpawner temp dir: “”
7: [2008/Feb/11|09:19:38] Application name (MAX/VIZ): “C:\Program Files\Autodesk\3ds Max 2008\3dsmax.exe”
8: [2008/Feb/11|09:19:38] --
9: [2008/Feb/11|09:19:38] Process id is 2912 (0xb60)
10: [2008/Feb/11|09:19:38] Executing ““C:\Program Files\Autodesk\3ds Max 2008\3dsmax.exe” -server \vraydummy90.max”
11: [2008/Feb/11|09:26:55] ========================== Ending session ==========================
