hello , i have problems with dr 1.5 , before i install 1.5 on my pc DR is working perfectely but now nothing works , any one had an idea about what i have to do to 1.5 DR work´s?
i´m getting this error " unknown error while loading application".
do i have to change any thing in the “WIBU Key”, i have install 1.5 in all machines but no one works.
regards
on all your machines make sure your licenses point to the server with the dongle installed - port 30304
I’ve had trouble rendering physical cameras over DR. Do you have problems with the regular camera?
hi , i do that in the “change V-ray client license setting” rigth? if yes , the number is ok “port 30304” its all done, but nothing works , this is the old problem with autodesk viz , i start the vray spawner and than viz2007 start and shutt down everytime until i shutt down vrayspawner.
dr with 1.5 what i´m doing wrong? closed for me_updated
ok, i have solved the problem i have replaced the new “vraydummy60.max” file and vraydummy60.xml by the old one that is working before i install vray 1.5 and now is working perfectly thank for your support.
regards
