DR with Backburner
Where are we on that issue ?
Currently this is the official answer:
Corona’s DR - it is only capable of rendering one single frame across multiple computers
Backburner - you may use all it’s features - rendering different frames per-PC, rendering time segments, rendering strips to save memory, etc
What issue do you mean specifically?
It was unable to use DR if you sending backburner job. I think it is a point.
ok for me, all the BackBurner features works well.
I mean send an image through BB and use DR on that image.
I’ve made some tests and it seems the job launch well, i can see the VFB on the node I’ve selected and I can see all the nodes in the DR Tab.
But the max sample doesn’t change, it take the same amount of time and passes than if i render the same pic only on one machine without using DR.
My question is :
Can I sent an image to be render in distributed via Backburner. Or it is much faster or simpler to strip that image ?
Ok
