DR with backburner
maybe a silly question and i´m sure there is already an answer out there…but it´s the first time i want to try it and i can´t find a solution…
i have 4 files…all are with DR (12 machines in the farm)…i want to render over the night so that the farm can render the the FILES one by one. i don´t want to share images..it´s just one still per file…is there a way to do it without being awake the whole night ? :slight_smile:
thanks
does video post work? setup your camera’s, output paths and such?
thanks for the tip..but these are 4 different files…not just 4 different cams
scratch that then…
Instead of DR, submit them through backburner using render stripes.
Currently you cannot do this since VRay cannot determine if it is started in slave mode by Backburner as a client machine, or as a slave for DR rendering.
thanks vlado…i expected this…but coffee works well, too :slight_smile:
