DR2 File Size limit
Hello, there seems to be a file size limit for DR2. I have a 14GB File, which doesn’t render with distributed rendering. It creates almost black renderings. Also the file transmitting to the node is much too fast. The node starts directly with rendering and produces black buckets.
Thanks.
C4D 2026.1.2 / latest Vray build / Win11 / CPU REndering / Bucket Mode
There are no such limits. Can you send us the scene in question so we can investigate what may have caused this?
Please open a ticket and attach it there.
Hello @zhanet.georgieva , it’s done and a link is sent. Thanks!
Hi, the issue has been logged (VC4D-2936). I will update you if there is any progress on it.
Hello @zhanet.georgieva , my weekly question, are there any news on fixes…? Is the nightlybuilds site down or why are there no updates since a while?
Hi @zhanet.georgieva, as a few months have passed since February (it’s already June), I thought I’d give it a go and ask if anyone has looked into this yet? Just to remind you: you have a scene from me and were able to reproduce the problem … so you have everything you need …
I’ll check this with the team and get back to you.
Hi @zhanet.georgieva, any news?
Hi @zhanet.georgieva you promised some information…
I have Render Node licences that I can’t use.
By the way, if that’s the intention: even Chaos Cloud doesn’t render projects on this scale… So this is a huge step backwards – rendering on a single local machine…
I need more time to finish projects that I can’t bill anyone for
I’ve been looking at the problem the last few days, I think I have an idea what’s going and hope a fix will be available soon.
Hi @bozhidar_ivanov ,thank you!
By the way it is another post I did, but, if you are rendering an animation and using more than two nodes, it happens sometimes, the rendering stops randomly, without any message.
Any Scene and always at different frame numbers, and sometimes it renders until end, but this happens only with more often with local plus one node only.
Hi @bozhidar_ivanov may I ask, any breakthrough?
Hi @bozhidar_ivanov I saw you are bussy with blenders, but any news on this?
@chaos don’t you think waiting for 7 months now is pain enough.?
Hi, may I ask if this fix is implemented in 7.4?
Ok I tested it myself, it doesn’t seem to be fixed… any idea when this could be ready, as you were close to fix this in an earlier post..
