The image data folder keeps getting larger and larger. (\AppData\Local\CoronaRenderer\DrData)
Shouldn’t it clear the folder after the Max directory size is reached (ie 10 gb)?
Will it only clear after each render is finished? Or will this happen during rendering.
The problem I’m now having is each render node is starting to run out of HDD space.
This didn’t seem to be an issue on Corona 2.
We are currently using:
Corona 3 Hotfix 2 with Deadline.
3dsmax 2018
Windows 10
The working folder is cleared after the job is finished. It is possible that it gets bigger than specified, but that should happen only if the scene and assets are really big (in case they are transferred to the node).
It can also happen in case some other application kills the DR server before it actually clears the folder (e.g. Deadline - however I am not sure if this is possible).
Hi! I need a bit more info to understand the problem better. Can you please answer the following:
What is your setup like? (Corona version, 3ds Max version, render manager, OS, etc.)
Are you using Corona DR or some other software’s?
Does the DR job stop suddenly or get cancelled before finishing?
Do you see any error messages when this happens?
Does this issue happen every time you render, even with a simple test scene?
If you manually delete everything from the DrData folder, does the issue still come back?
Is this issue only happening with one specific scene or with all your projects?
What is your setup like? (Corona version, 3ds Max version, render manager, OS, etc.) - 1 Workstation, 2 Nodes, Corona 12 Update 1, Max 2024, Windows 10, No render managers just standard DR, all machines connected to same network switch.
Are you using Corona DR or some other software’s? - Standard Corona DR - send from master workstation, both nodes have DR Server running
Does the DR job stop suddenly or get cancelled before finishing? - nope DR jobs complete as expected, except for maybe those that have the wxWidget error that I’ve discussed in another older thread
Do you see any error messages when this happens? When what happens? The only error message I’ve seen is that my C Drive is running out of space when I logged into the node
Does this issue happen every time you render, even with a simple test scene? No idea, I don’t regularly monitor the nodes
If you manually delete everything from the DrData folder, does the issue still come back? Not sure, I’ve cleared it but not sent any renders since
Is this issue only happening with one specific scene or with all your projects? Based on the fact it’s 170GB let’s assume it’s been going on for some time which would cover multiple scenes/projects
