Dreamscape and Vrayblend material
I use Dreamscape and I don’t want to use the dreamscape shader.
I would like to use a Vrayblend material to mix my water with the foam I generate like bmp files.
Well, If you add a Vrayblend material on a Dreamscape sea surface object Vray will crash.
Regards.
How does it crash? With the 3ds Max crash dialog, or just a V-Ray message?
Vray message, I have to restart max
Ok then; I will have to try and reproduce this here.
