DRLog in appdata folder query & nodes never starting issue.
The DRLog file in an appdata folder on a local pc on our network is only showing DRdata from January but we use it every day.
Does the local machine keep a DR Log or is it just on the nodes? Just a query.
ALSO
We are having an issue almost weekly on multiple machines where the nodes on our render farm will parse the scene and constantly try to start the render but never starts.
Restarting them has no effect, restarting the service has no effect and nothing in the troubleshooting guide works and it seems to be fine on other machines but occasionally itll stop working for just one user.
Its very intermittent and happens seemingly at random on files that were rendering fine the day before.
Opening a different file will work fine but the original file has been working fine for weeks.
EDIT: Looking at each node as soon as corona dr slave starts it becomes unresponsive in task manager then once it fails becomes responsive again
Max log:
2019/05/22 11:39:28 INF: [05512] [05516] Done loading file:  C:\Users\Administrator\AppData\Local\CoronaRenderer\DrData\corona_dr.max
2019/05/22 11:39:28 INF: [05512] [05516] SYSTEM: Production renderer is changed to Corona 3 (Hotfix 1). Previous messages are cleared.
2019/05/22 11:39:28 INF: [05512] [05516] Starting network rendering
2019/05/22 11:39:28 INF: [05512] [05516] Max is ready to begin render
2019/05/22 11:39:29 INF: [05512] [05516] Frame 0 assigned
2019/05/22 11:39:29 INF: [05512] [05516] Frame started at: 11:39:29
2019/05/22 11:39:29 INF: [05512] [05516] CORONA : Disabling 'max sample intensity' or setting it to high values can cause fireflies to appear in the image that will never go away.
2019/05/22 11:39:29 INF: [05512] [05516] BEGIN FRAME 0; TASK 1 OF 1; (NO SAVE);
2019/05/22 11:39:29 ERR: [05512] [05516] Render failed
2019/05/22 11:39:29 INF: [05512] [05516] END FRAME 0; TASK 1 OF 1; (NO SAVE); 0.078s; 0 faces; MEM 669 MB;
2019/05/22 11:39:29 ERR: [05512] [05516] Render Error (Render Frame)
2019/05/22 11:39:30 DBG: [05512] [05516] Interface8::LoadFromFile(C:\Users\Administrator\AppData\Local\CoronaRenderer\DrData\received_scene_789208448.max)
2019/05/22 11:39:30 INF: [05512] [05516] Starting to load file: C:\Users\Administrator\AppData\Local\CoronaRenderer\DrData\received_scene_789208448.max
2019/05/22 11:39:58 DBG: [05512] [05516] WARNING: The Populate data is missing on your system.
2019/05/22 11:40:09 INF: [05512] [05516] Done loading file:  C:\Users\Administrator\AppData\Local\CoronaRenderer\DrData\received_scene_789208448.max
2019/05/22 11:40:55 WRN: [05512] [05516] MAXScript FileIn Exception: -- Runtime error: viewport.activeViewport index out of range
2019/05/22 11:40:55 ERR: [05512] [05516] Error executing script
2019/05/22 11:40:59 DBG: [05512] [05516] Stop network
2019/05/22 11:41:06 DBG: [03828] [04448] Starting network
2019/05/22 11:41:06 INF: [03828] [04448] Application started with secure mode state 'OFF'
2019/05/22 11:41:06 INF: [03828] [04448] Product version: 3ds Max 2018.4 Update (20.4.0.4254)
2019/05/22 11:41:06 INF: [03828] [04448] Data collection and use is 'ON'. Change your participation anytime in the Help menu of 3ds Max.
2019/05/22 11:41:06 DBG: [03828] [04448] Could not find the specified file in DefaultSettingsParser::parse()
2019/05/22 11:41:10 DBG: [03828] [04448] Graphics driver requested by the user : Nitrous
2019/05/22 11:41:10 DBG: [03828] [04448] Graphics driver actually created in the viewports : null driver
2019/05/22 11:41:16 DBG: [03728] [06100] Starting network
2019/05/22 11:41:16 INF: [03728] [06100] Application started with secure mode state 'OFF'
2019/05/22 11:41:16 INF: [03728] [06100] Product version: 3ds Max 2018.4 Update (20.4.0.4254)
2019/05/22 11:41:16 INF: [03728] [06100] Data collection and use is 'ON'. Change your participation anytime in the Help menu of 3ds Max.
2019/05/22 11:41:16 DBG: [03728] [06100] Could not find the specified file in DefaultSettingsParser::parse()
2019/05/22 11:41:20 DBG: [03728] [06100] Graphics driver requested by the user : Nitrous
2019/05/22 11:41:20 DBG: [03728] [06100] Graphics driver actually created in the viewports : null driver
DRLog
2019-05-22 11:41:15   DR server started
2019-05-22 11:41:15   Binded to localhost
2019-05-22 11:41:15   Binding UDP socket to local address 192.168.74.47
2019-05-22 11:41:15   Running Corona DrServer build Dec 17 2018 on TCP/UDP ports 19666, loopback TCP/UDP19667
2019-05-22 11:41:15   Available 3dsmax versions:
2019-05-22 11:41:15   2018: C:/Program Files/Autodesk/3ds Max 2018/
2019-05-22 11:41:15   2017: C:/Program Files/Autodesk/3ds Max 2017/
2019-05-22 11:41:15   Running command:
"C:\Program Files\Autodesk\3ds Max 2018\3dsmaxcmd.exe" "C:\Users\Administrator\AppData\Local\CoronaRenderer\DrData\corona_dr.max"  -continueOnError -gammaCorrection:1 -rfw:1 -sf -v:5  -postRenderScript:"C:\Users\Administrator\AppData\Local\CoronaRenderer\DrData\post.ms"
2019-05-22 11:41:17   Started loopback connection with 3ds max
2019-05-22 11:41:18   Cannot contact 3ds Max, trying again ...
2019-05-22 11:41:18   3dsMax started successfully
2019-05-22 11:41:18   Accepted remote connection from 192.168.74.135
2019-05-22 11:41:18   Started connection #1
2019-05-22 11:41:18   Handshake: <root><DataType>0</DataType><Handshake>init</Handshake><FrameName>1</FrameName><HostVersion>Max2018</HostVersion><CameraName>CoronaCamera001</CameraName><Region>0 0 0 0</Region><ImageSize>3000 3000</ImageSize><MD5>8282461b83b04edac2f5205add133c47</MD5><CoreVersion>3 (Hotfix 1)</CoreVersion><IpAddress>192.168.74.135</IpAddress></root>
2019-05-22 11:41:18   Saving incoming scene to C:/Users/Administrator/AppData/Local/CoronaRenderer/DrData/received_scene_1475304589.max
2019-05-22 11:41:20   Downloaded scene: 185 M bytes in 1 s
2019-05-22 11:41:21   Render for connection #1 started
2019-05-22 11:41:21   Received sampling focus mask (region 0 0 3000 3000)
DrLog.txt is only used by DrServer.exe. If it is not running on your WS, no data/logs are created.
As for the issue, after a quick look it may be this:
https://forum.corona-renderer.com/ Distributed rendering - Connection failed
and that (linked in the thread above):
https://forum.corona-renderer.com/ [feedback] Render nodes don't start and max process remains idle in background
since the out of range error seems to be caused by the corona post.ms script.
Good Luck
Well thats certainly interesting. So if im understanding correctly i need to unlock the render view in the render settings, go back to the viewport and ensure that my active viewport is the camera im rendering from and then save the file and try to re-render?
Also thank sof rhe info on drserver. I thought it was the case but i didnt know if the local machine held a log of any submission errors.
Looks like. I never had this issue so why not just try it. It would also explain why it works/works not for the very same scene.
Good Luck
Thanks for your help :smiley:
