Is it possible to render only on the slave machine like vray?
Corona doesn’t seem to have that option on the DR options. Is there anyway to achieve that?
currently there is not the option, maybe it will be added in the future.
That would be great!
I usually prefer to render on the slave machines so that i can still work on some other stuff while its rendering without having that sluggish behaviour.
Here we currently just submit the job as a network job through Deadline, tell deadline to force workstation mode, while having enabled DR under the corona settings.
Job is sent to the network, picked up by 1 machine that goes into workstation mode (local rendering), and the DR settings starts as if you did it on your own machine.
But the result is exactly what you are after.
hey, thanks for the Tip snakebox, will try it ![]()
