Hello guys, i dont know if its a know issue but displacement doesnt work on blend materials, here is a pic to explain, at right regular corona material with displacement, at left blend with displacement material, both materials with the same displacement values on everithing.
It is known. This is probably most reported bug ;]
Oh thnaks, my bad.
It’s already fixed in daily builds. Is this in A7/A7.1?
A7.1 final
ok, then it is already fixed ![]()
thank you so much
Actually, it doesn`t work in A7.
Dont work, I’m trying to use in the version A7.1
maybe the formulation was little confusing: it is fixed, but not in A7. So it is expected to not work in A7/A7.1
