Dual Xeon E5-2670 or i7-5820k [mod: Thread now about 2670 only :) ]
Guys, I’ve stumbled upon this phenomenon just 3 days ago :- ) Completely random, I came across that Reddit thread which started it all in 2015.
There is a lot of information about it on internet, I did not bother searching much. I just bought the same board I use for my 2680v2.
I hope to have this PC completed in week +/- and then I will post a blog/tutorial quickly here to help others (if it will WORK :- ) ). But in meantime, I mean, there are about 200 such posts on internet :- )
Ive just snapped up a couple last night after reading this thread. It seems too good to miss for a cheap render node with some bite…if they work. Looks like they should CB R15 about 2000 points which is definitely worth the corona node license. I think sometimes people build many cheap nodes and forget that each node will need a render license which has an ongoing cost these days now vray has changed its pricing, so I think all major engines now charge for nodes.
As for Mobo I’m hovering over a Asus Z9 PA-D8 which looks to be the cheapest and supports DDR3 and strangely its ATX. It doesn’t seem as common as the other Asus boards which is surprising to me as being cheaper and ATX size I would have thought was appealing so not sure why it wasn’t popular at the time. It even has a VGA port. Anyone know if this isn’t a good option?
Im hoping to build this close to as cheap as I can within reason for a bit of an experiment as I wasn’t planning any major investment right now.
Yup, as Jann said, Asus Z9 PA seems like the cheapest option available in Europe. Are you 100perc. sure it supports non-ECC (U)Dimms ? The Asus only lists that on PE WS. If so it’s great choice. But both kind of memory should be plenty cheap available.
The board is strange, I didn’t even know it existed and it is younger then PE. It also looks incredibly cheap and shitty :- ) But that should matter at all.
2100 +/- C15 is excellent, in Corona Benchmark it has 1:48 seconds I think ?
I’ve just rechecked the spec page and it does support UDIMMS so I think we are safe. Although the supported RAM list is quite short and doesnt have any corsair RAM on it but I suspect its just not been tested by Asus. It does say in the small print it has to be 1600 or lower for the V1 which is worth noting.
Yes,but…
In server boards, UDIMMs in 90perc. of time simply mean Un(buffered/registered) ECC modules, so ECC modules not meant to be stacking in high amounts (clusters).
But if you checked the vendor list and found regular modules, then good, that’s what I was lazy to do (because why can’t Asus just link directly ?).
eee crap i’ve just ordered it but looking again I think you’re right. I googled UDIMM and just saw it meant unregistered so I thought I was in the clear with common DDR3. Looked more closely at the supported memory list and they were all ecc. Might have to cancel that. What a pain but my mistake!
EDIT: Trying to get hold of the seller by phone but can’t get through. But looking on the Crucial website I can get 2x8GB 1600 compatible EEC kits and if I bought 4 of them as I want 64GB then in terms of price it works out about the same as the WS mobo and RAM combo as I was going to get 2 x 32GB kits for that. Is it safe mixing 4 kits do you know? Another spanner is that there are about 5-6 different 2X8 GB kits, some unbuffered some with CL11 some CL13. I think CL11 is better but my knowledge is defo being tested. Might give them an email!
The Z9PE-D8 WS system I had with two 2660 C0 stepping ES xeons, worked fine with 4 kits of 2x8Gb ddr3 (KHX1600C10D3B1K2/16G)
The only trouble was setting the timings manually, as otherwise anything above 1333MHz would freak the ram out and show less amount. But once I set the correct timings, all 64Gb worked fine at full 1600MHz.
I have honestly never had trouble with mixing ram as long as it’s the same model, and you don’t AUTO everything. Though I even had an old Q9500 system with 2 kits from different brands working fine on auto too :smiley:
Thats good to know thanks. I have mixed two 32GB kits in one of my nodes and it seems to run fine with an OC’d i7 but was thinking server boards might be more picky.
I have since found a 64GB Kingston kit that would work out slightly cheaper and hopefully more reliable as its a kit. But its 4 x 16GB so I would only be using half the slots. Does that really matter if I have two free slots on each cpu? I dont think RAM speed effects rendering much? The only thing I can think of is loading the scene into the RAM but on a large still that is negligible.
Funny you say this because I had the exact issue with 1600Mhz but I didn’t tried playing with timings manually : / But I did performance comparisons and there was no difference so I just left it as it was…
Regarding mixing, it does work most of the time as long as they are set to same clock/timing (of the slower version), but I still wouldn’t suggest it…
Regarding free slots, it does not matter how many you fill, as long you fill same amount of slots for each CPU, in correct slots (A1/B1,etc…) as specified in manual. Even dual-channel/quad-channel does very little for performance.
http://www.ebay.com/itm/Intel-Xeon-CPU-E5-2670-SR0KX-2-60GHz-Eight-Core-LGA2011-20MB-Processor-QTY-100-/281816232417?hash=item419d8e71e1:g:TeQAAOSwKIpWDv3N
:- D
holy smokes there are tonnes of these things! If it all works out somebody could set up a render farm so cheaply. I’m hoping to bring it all in for £800 for the hardware. Probably about 35% of the cost of a new PC with the same CB scores.
I’ll go for the 4x16GB kit then.
I think there are less motherboards available than those chips :- ).
But what happened to those ? Are those being re-sold as barebone units ?
Hi guys
If you want some more insight on how a 2x E5-2670 render node build could look like and how it performs, I’ve posted my build over at cgarchitect:
Cheap 16core Xeon Node - Pros/Cons? - Hardware and Technical Discussions - CGarchitect Forums thread is running 5pages long atm, but I’m really happy with it. Images, performance, temps and thoughts regarding the build is all there.
Feel free to ask any questions and I’ll try my best to answer - I’m no Juraj on tech stuff though!
All inspiration came from http://www.techspot.com/review/1155-affordable-dual-xeon-pc/
http://www.amazon.com/Z620-Workstation-Processors-Professional-Installed/dp/B01E1SHJHI/ref=sr_1_3?ie=UTF8&qid=1464215094&sr=8-3&keywords=hp+z620+e5-2670
I just ordered one of these. I have a bunch of extra ram and a quadro card to chuck in it when it arrives. I live in New Zealand and after a lot of research this is the cheapest option for me. I also looked at dual socket motherboards with the c602 architecture and geez they’re expensive,
I guess I missed the boat when the E5-2670’s started flooding the market and all the boards got snapped up. The ram is cheap too as it’s ddr3 ecc which is no good for most computers :smiley:
Thats what i need.Thank you sir.
Love all the surprised posts on that thread in spirit of “Will it really work…but what’s the catch ?” :- )
Also 75Celsius is not a lot…these pedenatic people. Nonetheless, I too have under 55 because of good workflow and cooling for my 2680v2 (Fractal XL and 2xNoctua U12S does wonders even in horizontal push which I prefer for silence),
but it absolutely is not needed.
That full HP refurbished is OK deal too :- ) I mean it’s hard to find 2x those CPU plus board for much too much less anyway and you already get some memory, PSU and case as well. Just don’t forget to swap the fans (not heatsinks ! just fans for Noctua), to keep it quite, HP uses incredibly cheap shit, and they’re also been used for long time, their bearing mostly gone south.
Speaking of fans - anyone tried/compared Fractal Venturi fans?
Hey Jens what OS did u use on this system?
Thanks for the link Jens great to see your system up and running. I’m am far from an expert but I would say those temps are totally fine in my experience. Some people get obsessed by these things and the ‘acceptable limit’ gets less and less! I’ve only had one PC throttle and that was at 90 and a bought overclocked PC where they put in the wrong cooler!
I have just ordered the same mobo as you so great to see it successfully working well. I was scratching my head over coolers though so thanks for showing me you could squeeze those Noctuas in but crikey they are tight!
Which ram did you opt for in the end? You mentioned the kingston and the samsung? There is some cheap samsung RAM floating about on ebay I’ve noticed but its not on the Asus supported list, when other samsung models are.
Cheers
Yeah well put Juraj :smiley: my thoughts was that temps were fine too, but got spooked by all the post.
Win 10 Pro, just make sure to use the same user name as on your workstation on nodes (or credentials/access could be messy).
No problem Rhodesy, glad you found it usefull.
Yeah, they are pretty thight, I have to dismount one to flip the fans. But it works :smiley:
I went with the Kingston. Couldn’t find cheap ones from the Asus supported list, but the reseller assured me these would work. It was 8x this model: Memory D3 1600 8GB Kingston ECC R 1,5V (KVR16R11D8/8HB).
Thanks Jens. Shame they couldn’t have squeezed another couple of MM between sockets. I was looking at some cheaper coolers as they looked like an easier fit but the nocs are no doubt better at cooling.
