"Duplicate active sun found" error with only one sun in the scene
DB 2017-08-04 I get the attached error in the Corona Error Message dialog box. There is only one sun in the scene.
Are you sure you used no xref scenes with a sun in them?
Good Luck
Yes - see attached. The error doesn’t pop up consistently.
can I have the scene? Is it interactive or regular rendering?
I haven’t had this issue since the latest DB but I’ll let you know if it happens again.
problem went away
