I’ve imported an fbx file (from revit) into max and there appears to be thousands of duplicate objects (the duplicate objects have the exact same name as the original object). for eg. instead of 1 wall, I have 2 (both in the same spot). Does anyone know of a way to fix this (perhaps a script)? Trying to avoid doing this manually as it will take days! Thanks.
I’m curious to know if there is a script that could select the duplicates automatically.
It shouldn’t be too hard, although would never be fool proof.
I would say to have it find parts with the same number of faces/triangles who’s coordinates are the same should provide pretty accurate results.
It Would mess up though if you have a group of objects with the same topology, but the coordinates were all moved. I know some objects will import with the pivot at zero. In this case all but one would get selected for removal.
I’m pretty sure that case would be rare enough for the script to still be extremely useful.
I’m not too sure that would work on non-poly objects though. would be nice if there was maybe one that would work with those too. maybe the script could temporarily add an edit poly modifier, count the faces, then remove it. I’m not sure if that would work though.
